Cant find music assistant integration
Hello, I installed Music Assistant and Home Assistant in Docker container using this Docker compose file:
services:
  homeassistant:
    container_name: homeassistant
    image: "ghcr.io/home-assistant/home-assistant:stable"
    volumes:
      - /home/user/HASS:/config
      - /etc/localtime:/etc/localtime:ro
      - /run/dbus:/run/dbus:ro
    restart: unless-stopped
    privileged: true
    network_mode: host
  nginxproxymanager:
    image: 'jc21/nginx-proxy-manager:latest'
    ports:
      - '80:80'
      - '81:81'
      - '443:443'
    volumes:
      - ./nginx/data:/data
      - ./nginx/letsencrypt:/etc/letsencrypt
  music-assistant-server:
    image: ghcr.io/music-assistant/server:latest # <<< Desired release version here (or use beta to get the latest beta version)
    container_name: music-assistant-server
    # Network mode must be set to host for MA to work correctly
    network_mode: host
    volumes:
      - ${USERDIR:-$HOME}/Docker/music-assistant-server/data:/data/
    # privileged caps (and security-opt) needed to mount smb folders within the container
    cap_add:
      - SYS_ADMIN
      - DAC_READ_SEARCH
    security_opt:
      - apparmor:unconfined
    environment:
      # Provide logging level as environment variable.
      # default=info, possible=(critical, error, warning, info, debug)
      - LOG_LEVEL=info
After installing I restarted home assitant’s container, and when looking in my integrations, I can’t seem to find my desired one:
does anyone know what I have missed?
thanks
Hello Amit,
Is there any particular reason you didn’t ask here in Music assistant? The people that are watching that thread are all either interested. users of, or authors of Music Assistant. They are likely your best resource.
There is also a discord server for it. Not certain if this invite link still works, but here it is.
