OK, I am really not getting thru to you at all…
First off, you really need to stop turning your pi off. It’s been almost two months since we have started on this. If you don’t trust your Pi to stay on all the time by now then I doubt you ever will.
If you don’t want the pi running all of the time then you will never ever be able to use it as a home automation system. If you don’t ever use it as a home automation system then there is no point in continuing on with this because it will never get used for the intended purpose.
you need to decide if you really want HA to run as a home automation system. If you do then leave the pi on. If you don’t want to leave the pi on then you need to stop wasting your (and my) time trying to get something running that you won’t ever use.
I really (obviously…) don’t mind helping but I don’t want to waste my time if the end result is not going to be used.
But to continue on with the main issue…
of course they are all empty. you have to select them for them not to be empty.
let’s try this a different way.
Here is what my Zwave config area looks like when I first open it up. See, none of the drop downs are filled in:
then when I select a node then there are more drop downs that are empty until I select them:
then when I select (for example) the node config options it will be empty until I select a parameter to change. Then iot shows me what the parameter setting is and it’s current value:
At what point in the above sequence are you saying “they are all empty” and that you “have to set them”?
All of those settings that you could change in any of the configuration drop downs SHOULD NOT CHANGE until you tell them to change. rebooting/restarting shouldn’t be causing them to change. If they really are changing then you have another problem. BUT I really don’t think that is the issue.
You know at this point maybe I really do need to get into your system to see what’s going one so we stop going in circles on this. you mentioned before about using Chrome Remote Desktop. I’ve never used it but I just looked at it and it seems to be fairly straight forward.
If you still want me to do that I can. Just PM me the access code and we can work out a way that we can coordinate our time.
