I have installed hassio on a raspi4 using this image haos_rpi4-64-7.6.img.xz
I have the supervisor but I can’t find the snapshot backup function
The only backup function that I can find is
By the I often see the supervisor in the panel but that entry is missing for me.
Thanks!
Pippyn
2
That is the snapshot backup function. You have found it
The supervisor was relocated recently.
tom_l
3
And “snapshots” were renamed “backups”.
Things change pretty quickly around here. There is a lot of outdated information in blogs, on youtube and here on the forum. Always check the docs. https://www.home-assistant.io/common-tasks/os/#making-a-backup-from-the-ui
Hi, thanks for the information…
How can I make automatic backups? Only found this tutorial https://suburbannerd.com/hassiobackup/
Thanks!
tom_l
5
If you have a NAS then Samba Backup is excellent. Otherwise all of the options on this list have automated backup functions:
https://www.home-assistant.io/common-tasks/os/#copying-your-backups-to-another-location
I am using now this great add-on from that list above!
