Can't find the floorplan card after installing via hacs
I have installed floorplan via hacs. The resource was automatically added to lovelace. I have cleared my cache and refreshed my browser many times now. But for the love of god, i can’t seem to be able to add the floorplan card to my dashboard since i can’t find it.
I recently started using home assistant, so i am a total noob. Therefore the floorplan “quick guide” is totally useless to me since it assumes that i have any knowledge of adding resources to home assistant. So i just assume that the ‘resource’ part is already done since the floorplan was already automatically added?
Can anyone give any guidance?
Configuration
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Text to speech
tts:
  - platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
light: !include light-groups.yaml
sensor: !include sensors.yaml
binary_sensor: !include binary-sensors.yaml
switch: !include switches.yaml
homeassistant:
  customize: !include customize.yaml
frontend:
    themes: !include_dir_merge_named themes
nevermind. found it
Hi Tom
Have the same problem.
Would you mind giving the solution??
Did you do step 5 that @nightwalker showed above?
Sorry, i just read this. The solution is in the original post. although not very visible. I have highlighted step 5 (red underline). I believe that was the solution for me. I just didn’t read the instructions properly :wink:
