Hi Every one, I am trying to trigger a switch when the current is above a certain level.
lets say turn boolean switch on if the current is above 2.0A , I did that but noting happen.
do it need to be below 2 fist before it switch when it pas the 2?
yes the value (assuming you are using a numeric trigger since you didn’t post any useful info) needs to go below then above before it triggers.
yes the value has to transition from below 1.0 to above 1.0 for the trigger to work.
Thanks, i will adjust it so i can try it out and then put the real automation in place
