Can't Find WLED Device
Having hard time adding device to existing list of WLED devices (already have 3 up and running).
My HA GUI doesnt return any errors
wled_bug
But in log it is recorded:
File "/usr/local/lib/python3.11/site-packages/aiohttp/web_protocol.py", line 452, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.11/site-packages/aiohttp/web_app.py", line 543, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.11/site-packages/aiohttp/web_middlewares.py", line 114, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 85, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 100, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 28, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 80, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 233, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/headers.py", line 31, in headers_middleware
response = await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 149, in handle
result = await handler(request, **request.match_info)
File "/usr/src/homeassistant/homeassistant/components/http/decorators.py", line 63, in with_admin
return await func(self, request, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 177, in post
return await super().post(request, flow_id)
File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 72, in wrapper
result = await method(view, request, data, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 110, in post
result = await self._flow_mgr.async_configure(flow_id, data)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 323, in async_configure
result = await self._async_handle_step(
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 419, in _async_handle_step
result: FlowResult = await getattr(flow, method)(user_input)
File "/usr/src/homeassistant/homeassistant/components/wled/config_flow.py", line 40, in async_step_user
device = await self._async_get_device(user_input[CONF_HOST])
File "/usr/src/homeassistant/homeassistant/components/wled/config_flow.py", line 117, in _async_get_device
return await wled.update()
File "/usr/local/lib/python3.11/site-packages/backoff/_async.py", line 151, in retry
ret = await target(*args, **kwargs)
File "/usr/local/lib/python3.11/site-packages/wled/wled.py", line 256, in update
if not (data := await self.request("/json")):
File "/usr/local/lib/python3.11/site-packages/wled/wled.py", line 188, in request
response = await self.session.request(
File "/usr/local/lib/python3.11/site-packages/aiohttp/client.py", line 541, in _request
req = self._request_class(
File "/usr/local/lib/python3.11/site-packages/aiohttp/client_reqrep.py", line 326, in __init__
self.update_headers(headers)
File "/usr/local/lib/python3.11/site-packages/aiohttp/client_reqrep.py", line 431, in update_headers
if self.url.port is not None and not self.url.is_default_port():
File "/usr/local/lib/python3.11/site-packages/yarl/_url.py", line 525, in port
return self._val.port or DEFAULT_PORTS.get(self._val.scheme)
File "/usr/local/lib/python3.11/urllib/parse.py", line 182, in port
raise ValueError(f"Port could not be cast to integer value as {port!r}")
ValueError: Port could not be cast to integer value as '//51.32.0.110/:80'
2024-01-05 01:10:20.711 ERROR (SyncWorker_3) [miio.miioprotocol] Got error when receiving: timed out
I am running HA
* Core 2024.1.0
* Supervisor 2023.12.0
* Operating System 11.2
* Frontend 20240103.3
and WLED 0.14.0 (build 2310130) on Espressif ESP8266-DevKitC
Since I’m new user I can’t post a screenshot of my WLED Wi-Fi setup, but I can prob. share it accordingly.
Static IP address is reserved via Router by MAC address.
Can anyone help on this I would rly appreciate?
Did you read that screen you are typing on, right under the entry line?
Valid hostname or ip address goes there. Hostnames do not have spaces in them. I suggest strongly that you set the IP address to a fixed address and type the IP address in there.
Have you read this part of the thread?
And also where have you seen any spaces since i didnt? Neither did console as far as I can see.
ValueError: Port could not be cast to integer value as //51.32.0.110/:80
Quick update on thread,
After updating HA to
* Core 2024.1.0
* Operating System **11.3**
It found lights by itself.
