Hello all,
I am a quite the Noob, but I have managed to get most things working. I am doing an updated Home Assistant Core on a Rpi4 (fresh install) and in preparation I will be using ZHA with the Nortec dongle (used deCONZ in my last install). I then went to configuration > integrations > and scrolled down to find ZHA. I can’t find it. At first I thought maybe my spelling was wrong but it is unavailable on both my installs. Here is what I am presented with:
I also searched to see if I could find any documentation that mention it no longer being available. Am I missing something? Has this been deprecated?
Thank you for your guidance and suggestions.
Edit: THIS ANSWER IS RUBBISH. See below
The integration is called something more user friendly than a TLA
Look for Z-wave
(TLA = three letter acronym)
Thank you! But isn’t ZHA for Zigbee? I have Z-Wave showing up in integrations.
Ups, yes. I mixed them up because you also taked about deconz so I read it as adding a zwave dongle.
ZHA is actually called ZHA and I can see it when I try to add an integration.
It is the one right after Z-wave in the list and the very last in the list. Maybe you cannot scroll down all the way. i have noticed that problem in some browsers. Then it helps trying again, maybe changing the browser to full screen
Sorry for my mixup.
And yes. I do not like acronyms used in user interfaces
Thank you for letting me know. I got a touch confused, but all is clear now. I will take your advice and try with a different browser to see if I can find it
Spectacular! Your advice was right on. Once I opened my browser to full screen I was able to see the top of the ZHA.
