Can't find zoneminder integration
Running latest HA but can’t find “zoneminder” or “zone minder” or anything like that when I add new integration yet it shows up on the website as an integration that should be available.
Is there a way to refresh integrations or is something not supported with zoneminder in 2022.3?
ZoneMinder - Home Assistant (home-assistant.io)
You need to add your integration using yaml, not UI
what @anon63427907 said is quite right, but what surprises is that you even pointed to the instructions.
