I have two generic thermostats for two zones. I can’t seem to get them both to work. A single one works but when I add the second, only the living room zone works.
e.g. both have a set point of 23 degrees (celsius) with tolerance of 1 degree.
Bedroom: 19 degrees, should be calling heat but is idle
Living: 21.5 degrees, calling heat
Any thoughts about what I might be doing wrong?
configuration.yaml
climate:
- platform: generic_thermostat
heater: switch.hvac_hvac_bedroom
target_sensor: sensor.bed_1_temperature
min_cycle_duration: 20
tolerance: 1
heater: switch.hvac_hvac_living
target_sensor: sensor.living_temperature
tolerance: 1
The result is such as below:
