a set of entity cards in a horizontal stack to show temperature abs humidity. on my mobile it looks fine in landscape but no so in portrait. how can i fix this perhaps using different cards. i just want the 4 pairs of readings across the page.
You can’t. Dashboard cards are designed to float independently, so that on a mobile in portrait mode they appear as a single column, in landscape they appear in two or three columns (probably not four). A horizontal stack would only normally be used in large displays.
Start by showing you code, as noone can guess whether you use “default masonry” neither which "settings you use for your “View” Nor whether you use i.e Stacks, or Grid
So the answers you get will only be based upon assumptions and guesses
And if for some reason, you use Panel mode, and grid, you a doomed, unless you use %, and then your 4 cards(not 4 pairs) would be so tiny you cant read them.
