Hello @HypnoToad,
Thanks for fast reply. What do you mean as port?
My HA istance is available on 443 (ssl) with a Let’s Encrypt valid certificate. Actually it’s filtered (available) only by Amazon IPs by a firewall, but even allowing any, it’ doesn’t change.
Like you, until the account linking, all works well, even the discovery test with the long access token.
Simon
I was originally running my HA instance on a different port, something like port 55555 and Amazon didn’t like it.
I tried again this time with my HA instance on port 443 and it is now working for me. I’m also using a Let’s Encrypt certificate, so I’m not really sure why it’s not working for you I’m afraid.
Which HA versione do you have?
I’m having it on docker, 0.97.2.
I’ve no idea how to test it manually as well I mean the account linking.
I’ve opened a case on Alexa Devel as well, to have some logs
So what happens when 443 isn’t an option? I am running on 8123 and publicly accessible and using a GoDaddy cert. I have something else running on 443 so that’s not an option. I’ve read something about lambda proxies that can deal with this but have no idea what to do. Assuming you run some kind of proxy on Amazon’s servers on 443 and it redirects traffic to 8123 in my case for any lambda function you are running but no clue.
I’m having this issue as well - using the LONG_LIVED_ACCESS_TOKEN testing I am able to view the device without issue.
However unable to link now. I was able to link previously however once I disable and enable linking I’m getting the “We were unable to link Home Assistant at this time”
