having used the built-in sounds for a long time, I decided to try import and play the system sounds, as described on https://companion.home-assistant.io/docs/notifications/notification-sounds#importing-sounds-from-ios
However, using the below sequence doesn’t make it happen. The badge is set to 99 alright, as is the message notified, so I know the service is executed. The commented parts work fine too.
- service: notify.mobile_app_calltheboss
title: >
{% set room = trigger.to_state.object_id.split('_sensor_motion')[0].replace('_',' ')|capitalize %}
Alarm triggered in the {{room}}
message: >
{{as_timestamp(now())|timestamp_custom('%X')}}: {{room}} triggered the alarm, check whats up!
push:
badge: 99
category: alarm
critical: 1
volume: 1.0
sound:
# sound: US-EN-Morgan-Freeman-Motion-Detected.wav
# attachment:
# url: 'https://github.com/home-assistant/assets/blob/6a407898bd8ae80eb83634ffddb0d5ebdde95957/logo/logo.png?raw=true'
# content-type: "png"
# hide-thumbnail: false
Secondly, as you can see I try to use the actionable notification on the category: alarm
, which I have also created:
ios:
push:
categories:
- name: Alarm
identifier: alarm
actions:
- identifier: SOUND_ALARM
title: Sound Alarm
activationMode: background
destructive: yes
authenticationRequired: true
- identifier: SILENCE_ALARM
title: Silence Alarm
this doesn’t show up in the notification on my mobile, while others I have made do. I dont understand why this would not show the 2 options in the popup, like on the documentation
The Category is listed correctly in the App, alongside the others I previously created.
update
contrary to the syntax in the documentation, I hadn’t used the sound: object, and had the options listed incorrectly, sorry about that
sound:
critical: 1
volume: 1.0
does work.
leaves the actionable notification to be solved…
Please have a look what I am missing here? thanks!
