Cant Get Alexa to Integrate with HA
Hi All,
I got HA Yellow last month Feb 2025 (moved on from Samsung ST), updated the core and all up to date.
Spent a lot of hours configuring through HA forum on added Emulated HUE and updated Config file. Tested that entities are exposed, however, no matter what I tried, Alexa does never pick it up, never able to discover devices.
PLs let me know if i am missing anything:
below is the config file updated
It works and give me exposed entities when i ping - http:///api/v2/lights
Tried then discovery on Alexa device and app. no success.
please help, appreciate it.
# Example configuration.yaml entry
emulated_hue:
  host_ip: <IP ADD>
  listen_port: 80
  off_maps_to_on_domains:
    - script
    - scene
  expose_by_default: false
  entities:
    switch.in_wall_outlet_tr_500s_7:
     hidden: false
    switch.in_wall_outlet_tr_500s_5:
     hidden: false
hi, can anyone pls help. Tried everything and dont want to pay for cloud sub.
those are invalid quote characters. Just remove them, they aren’t needed anyways.
Hi Petro, thanks a lot, I removed the quotes but still unable to discover the devices on Alexa.
I did confirm that i am able to expose the entities on Alexa when i ping http://(IP)/api/v2/lights
result:
“25”: {
“state”: {
“on”: false,
“reachable”: true,
“mode”: “homeautomation”
“name”: “right stand”,
“uniqueid”: “00:cc:46:62:56:58:ff:21-12”,
“manufacturername”: “Home Assistant”,
“swversion”: “123”,
“type”: “On/Off light”,
“productname”: “On/Off light”,
“modelid”: “HASS321”
thanks a lot for your help in advance!
Vick
