Can't get Ali express button to work
I ordered 2 buttons from Ali express https://www.aliexpress.com/item/1005002469399775.html?spm=a2g0s.9042311.0.0.594d4c4dNxBSCa.
They couldn’t be found with smart life but pairing was possible with HA and a cc2531 and shows the following info:
Zigbee info
IEEE: 80:4b:50:ff:fe:e0:fe:67
Nwk: 0x4c7e
Device Type: EndDevice
LQI: 49
RSSI: Unknown
Last Seen: 2021-06-23T15:46:10
It doesn’t show as a button and don’t know how to use it as a button. I’m already happy if I can use this button to toggle lights, but preferable also use it to dimm lights, or press button fast to control more?
I’m completely lost how to continue and hope for some help.
Now using online a single button switch, but also have one with 2 buttons :slight_smile:
Please show the device signature, not only the info.
  "node_descriptor": "NodeDescriptor(byte1=2, byte2=64, mac_capability_flags=128, manufacturer_code=4098, maximum_buffer_size=82, maximum_incoming_transfer_size=82, server_mask=11264, maximum_outgoing_transfer_size=82, descriptor_capability_field=0, *allocate_address=True, *complex_descriptor_available=False, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=True, *is_full_function_device=False, *is_mains_powered=False, *is_receiver_on_when_idle=False, *is_router=False, *is_security_capable=False, *is_valid=True, *logical_type=<LogicalType.EndDevice: 2>, *user_descriptor_available=False)",
  "endpoints": {
    "1": {
      "profile_id": 260,
      "device_type": "0x0000",
      "in_clusters": [
        "0x0000",
        "0x0001",
        "0x0006"
      "out_clusters": [
        "0x000a",
        "0x0019"
  "manufacturer": "_TZ3000_q68478x7",
  "model": "TS0041",
  "class": "zigpy.device.Device"
Those cheapo chinese tuya devices tend to be cloned all over the place with semi-random manufacturers.
I’ve created a PR for this one to be added to the ZHA quirks:
Hi Koying,
Many many tnx. Because I’m a real real newby, what should I do with your code.
Sorry hahahaha
