is there anything special you needed to do to get the androidtv integration connected to your Shield?
I have enabled developer options and turned on debugging over the network (which I think is required) but I still fail to connect when attempting to configure the integration. I’m also running the latest version (9.1.1) of the Shield software.
I have successfully set up the androidtv notifications integration and those notifications are working fine so the basic infrastructure is there.
I just don’t know what I’m missing with the androidtv integration.
I didn’t realize I had a prompt to accept debugging commands on the Shield.
I had tried it again with a failure to connect and then just happened to turn on the TV shortly after that and there was the prompt (I never saw that prompt before now tho - maybe it had timed out? ). I accepted it and then had to go back in to HA and set up the host manually again and it connected.
