Can't get buttons to toggle switches on Blitzwolf BW-SHP7 and BW-SHP9 in esphome?
I’ve gotten a few BW-SHP7 (double socket smart switch) and a BW-SHP9 (tripple socket smart switch).
I’ve gone through the migration from Tasmota to ESPHome, and I got the relays working, and on the SHP7 the powermonitoring is working as well.
But on neither of them I can get the buttons to work. The relays works fine through HomeAssistant.
On SHP7 there are two buttons, one for each socket.
On SHP9 there are only one button, for the four relays (3 sockets and one double USB output).
The SHP9 looks like this in tasmota:
The code for the SHP9 looks like this so far, I’ve tried both with on_press, on_click, on_double_click and multiclick, but so far without luck.
substitutions:
  device_name: livingroomextension
  # NO Powermeasurement
  # BW-SHP9
esphome:
  platform: ESP8266
  board: esp8285
  on_boot:
    then:
      - switch.turn_on: relay1
      - switch.turn_on: relay2
#      - switch.turn_on: relay3
      - switch.turn_on: relay4
wifi:
  ssid: !secret wifissid
  password: !secret wifipw
#  reboot_timeout: 60min
  manual_ip:
    static_ip: 10.11.13.44
    gateway: 10.11.13.1
    subnet: 255.255.255.0
#  use_address: 10.11.12.201
  fast_connect: true
  ap:
    ssid: "${device_name} Hotspot"
    password: !secret appw
logger:
  baud_rate: 0
web_server:
  port: 80
  auth:
    username: !secret webuser
    password: !secret webpw
api:
ota:
  password: !secret otapw
time:
  - platform: homeassistant
text_sensor:
  - platform: version
    name: "${device_name} ESPHome Version"
  - platform: wifi_info
    ip_address:
    ssid:
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO13
    on_click:
      min_length: 50ms
      max_length: 350ms
      then:
      - switch.toggle: relay1
  - platform: gpio
    pin:
      number: GPIO13
    on_double_click:
      min_length: 50ms
      max_length: 350ms
      then:
        - switch.turn_off: relay2
#    - timing:
#        - ON for at most 1s
#        - OFF for at most 1s
#        - OFF for at least 0.2s
#      then:
#        - switch.toggle: relay2
#    - timing:
#        - ON for 1s to 2s
#        - OFF for at least 0.5s
#      then:
#        - switch.toggle: relay4
#    - timing:
#      then:
#        - switch.toggle: relay1
switch:
  - platform: gpio
    pin: GPIO12
  - platform: gpio
    pin: GPIO14
  - platform: gpio
    pin: GPIO5
  - platform: gpio
    pin: GPIO15
status_led:
  pin:
    number: GPIO0
  - platform: wifi_signal
    name: '${device_name} wifi signal'
    update_interval: 60s
    accuracy_decimals: 0
  - platform: uptime
    unit_of_measurement: days
    update_interval: 300s
    accuracy_decimals: 1
    filters:
      - multiply: 0.000011574
My SHP7 looks like this:
substitutions:
  device_name: serverroompower
  # Higher value gives lower watt readout
  current_res: '0.002291'
  # Lower value gives lower voltage readout
  voltage_div: '940'
esphome:
  platform: ESP8266
  board: esp8285
  on_boot:
    then:
#      - switch.turn_on: relay2
wifi:
  manual_ip:
    static_ip: 10.11.13.43
    gateway: 10.11.13.1
  fast_connect: true
  ap:
logger:
  baud_rate: 0
web_server:
  port: 80
  auth:
api:
ota:
time:
text_sensor:
  - platform: version
    ip_address:
    ssid:
binary_sensor:
  - platform: gpio
    internal: true
    pin:
      number: GPIO0
    on_press:
  - platform: gpio
    internal: true
    pin:
      number: GPIO15
    on_press:
output:
   - platform: esp8266_pwm
     pin:
       number: GPIO13
       inverted: true
     pin:
       number: GPIO2
       inverted: true
#  - platform: gpio
#    pin: GPIO13
#    inverted: true
#    id: led1
#  - platform: gpio
#    pin: GPIO02
#    inverted: true
#    id: led2
switch:
  - platform: gpio
    pin: GPIO14
    on_turn_on:
      - output.turn_on: led1
    on_turn_off:
      - output.turn_off: led1
  - platform: gpio
    pin: GPIO16
    on_turn_on:
      - output.turn_on: led2
    on_turn_off:
      - output.turn_off: led2
status_led:
  pin:
    number: GPIO01
    inverted: true
  - platform: uptime
    filters:
  - platform: hlw8012
    sel_pin:
      number: GPIO03
      inverted: true
    cf_pin: GPIO04
    cf1_pin: GPIO05
    current_resistor: ${current_res}
    voltage_divider: ${voltage_div}
    current:
      unit_of_measurement: 'A'
      accuracy_decimals: 3
      icon: mdi:flash-outline
    voltage:
      unit_of_measurement: 'V'
    power:
      unit_of_measurement: 'kW'
      accuracy_decimals: 5
      filters:
        - multiply: 0.001
    change_mode_every: 4
    update_interval: 10s
  - platform: total_daily_energy
    name: '${device_name} daily energy'
    power_id: power
    unit_of_measurement: kWh
On the SHP7 the LED’s work, powermonitoring, relays, but still no buttons.
Any help out there?
I got the BW-SHP9 working!
as well as the BW-SHP7!
