I’ve been using HA with conbee 2 for a few years and it worked fine till today. I have raspberry pi 4, 64 bit image sconbee connected to USB 2 port.
I wanted to start fresh today, reset the conbee 2 and flashed a new image of HA. Setup goes fine, conbee2 is discovered. I can install deconz and configure (there are 2 options, one short and one long:
- /dev/ttyAMA0
- /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2190044-if00
I am not sure but I have tried a few times. First way:
On discovered devices, I configure conbee. Ok so far:
Then install deconz latest from the add on store and configure it (here I’m also not sure which unit to choose). I can log into deconz and add devices but then I go back to discovered devices and now:
I have these errors in the log:
Couldn’t start deCONZ = dresden elektronik deCONZ protocol: ConBee I/II, RaspBee I/II coordinator
20:02:19 – (ERROR) Zigbee Home Automation - message first occurred at 20:00:57 and shows up 5 times
No response to ‘Command.read_parameter’ command with seq id ‘0x02’
20:02:19 – (WARNING) components/zha/core/gateway.py - message first occurred at 20:00:57 and shows up 5 times
Config entry ‘ConBee II - /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2190044-if00, s/n: DE2190044 - dresden elektronik ingenieurtechnik GmbH - 1CF1:0030’ for zha integration not ready yet; Retrying in background
20:00:57 – (WARNING) config_entries.py
I have also tried different USB ports. I’ve spent all day with this, I cant figure it out. Thank you in advance.
edit1:
After many hours and tests I tried flashing todays latest firmware from:
https://deconz.dresden-elektronik.de/deconz-firmware/?C=M;O=D
but the problem is still there. Is there a certain firmware I need? (I flashed with this version deCONZ_ConBeeII_0x26780700.bin.GCF)
