After following the docker install (https://www.home-assistant.io/docs/installation/docker/) on Rpi I just can’t get the container to start.
Could somebody give me a pointer to what I’m missing? ( of course I already googled for a couple of hours ;-).
I’m trying to run it with
sudo docker run --init -d --name="home-assistant" -e "TZ=America/New_York" -v /home/pi/homeassistant:/config --net=host homeassistant/raspberrypi3-homeassistant:stable
With the result
pi@testpi:~ $ docker ps -a
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
c37fbc9e957a homeassistant/raspberrypi3-homeassistant:stable "/init" 13 seconds ago Exited (129) 8 seconds ago home-assistant
And the container log is
pi@testpi:~/homeassistant $ docker logs home-assistant
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] udev.sh: executing...
[cont-init.d] udev.sh: exited 267.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
My docker install should be fine, as I’m able to run a test container.
Thanks in advance for the help!
