I know there was an issue since version .56.2, but we are on 0.57.3 now and the issue is solved.
But I do not get my USB300 Enocean dongle and 3 Eltako switches setup.
If I press the Eltako’s, I get a lightsignal on the usb dongle, so there is a connection.
I only do not see any action in the logfiles. HAve set the logs on debug.
I’m running hass.io version 0.57.3 and also have an rfxcom device (which is working fine)
This is my from my dmesg | grep USB
[ 2.133316] usb 1-1.3: new full-speed USB device number 4 using dwc_otg
[ 2.264843] usb 1-1.3: New USB device found, idVendor=0403, idProduct=6001
[ 2.264855] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.264861] usb 1-1.3: Product: EnOcean USB 300 DB
[ 2.264867] usb 1-1.3: Manufacturer: EnOcean GmbH
[ 2.264873] usb 1-1.3: SerialNumber: FTO655H
[ 2.353321] usb 1-1.5: new full-speed USB device number 5 using dwc_otg
[ 2.478119] usb 1-1.5: New USB device found, idVendor=0403, idProduct=6001
[ 2.478134] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.478147] usb 1-1.5: Product: RFXtrx433
[ 2.478158] usb 1-1.5: Manufacturer: RFXCOM
[ 2.478170] usb 1-1.5: SerialNumber: A1Z7CBL2
[ 5.867733] usbcore: registered new interface driver brcmfmac
[ 8.408879] usbcore: registered new interface driver usbserial
[ 8.408976] usbcore: registered new interface driver usbserial_generic
[ 8.409066] usbserial: USB Serial support registered for generic
[ 8.579278] usbcore: registered new interface driver ftdi_sio
[ 8.580685] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 8.581186] usb 1-1.3: Detected FT232RL
[ 8.582713] usb 1-1.3: FTDI USB Serial Device converter now attached to ttyUSB0
[ 8.582987] usb 1-1.5: Detected FT232RL
[ 8.583963] usb 1-1.5: FTDI USB Serial Device converter now attached to ttyUSB1
this is from my configuration.yaml:
#rfxcom
rfxtrx:
device: /dev/ttyUSB1
debug:
- platform: rfxtrx
automatic_add: True
#Enocean USB300
enocean:
device: /dev/ttyUSB0
and
binary_sensor:
- platform: rfxtrx
automatic_add: True
- platform: enocean
# FEF8A1YY
- platform: enocean
# FEF8B8YY
- platform: enocean
# FEF8A1YY
This is my logging
logger:
default: critical
logs:
# homeassistant.components: debug
homeassistant.components.enocean: debug
# homeassistant.components.rfxtrx: debug
from the logs:
2017-11-15 09:25:09 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.enocean
2017-11-15 09:25:10 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.enocean
If i press the switches i get nothing. no entry in the log, nothing whatsoever.
the log shows:
Recv: 0x08 0x50 0x02 0x01 0x09 0x02 0x00 0xb2 0x69
decrypt_verify(): found 24 bytes cleartext
Recv: 0x08 0x50 0x02 0x02 0x09 0x02 0x00 0xb2 0x69
Recv: 0x08 0x50 0x02 0x03 0x09 0x02 0x00 0xb2 0x69
Recv: 0x08 0x50 0x02 0x04 0x09 0x02 0x00 0xb2 0x69
Recv: 0x08 0x50 0x02 0x05 0x09 0x02 0x00 0xb2 0x69
Recv: 0x08 0x50 0x02 0x06 0x09 0x02 0x00 0xb1 0x69
Recv: 0x08 0x50 0x02 0x07 0x09 0x02 0x00 0xb2 0x69
Recv: 0x08 0x50 0x02 0x08 0x09 0x02 0x00 0xb2 0x69
Recv: 0x08 0x50 0x02 0x09 0x09 0x02 0x00 0xb1 0x69
Recv: 0x08 0x50 0x02 0x0a 0x09 0x02 0x00 0xb1 0x69
Recv: 0x08 0x50 0x02 0x0b 0x09 0x02 0x00 0xb1 0x69
Recv: 0x08 0x50 0x02 0x0c 0x09 0x02 0x00 0xb1 0x69
Recv: 0x08 0x50 0x02 0x0d 0x09 0x02 0x00 0xb1 0x69
Recv: 0x08 0x50 0x02 0x0e 0x09 0x02 0x00 0xb1 0x69
Recv: 0x08 0x50 0x02 0x0f 0x09 0x02 0x00 0xb1 0x69
Recv: 0x08 0x50 0x02 0x10 0x09 0x02 0x00 0xb1 0x69
Recv: 0x08 0x50 0x02 0x11 0x09 0x02 0x00 0xb1 0x69
Recv: 0x08 0x50 0x02 0x12 0x09 0x02 0x00 0xb1 0x69
Recv: 0x08 0x50 0x02 0x13 0x09 0x02 0x00 0xb1 0x69
Recv: 0x08 0x50 0x02 0x14 0x09 0x02 0x00 0xb1 0x69
Recv: 0x08 0x50 0x02 0x15 0x09 0x02 0x00 0xb1 0x69
Recv: 0x08 0x50 0x02 0x16 0x09 0x02 0x00 0xb1 0x59
Recv: 0x08 0x50 0x02 0x17 0x09 0x02 0x00 0xb1 0x59
core-ssh:~#
But this has nothing to to with the enocean i guess
I am at my wits end. What am I doing wrong ?
Any help would greatly be appriciated.
Regards
Bert
