I have an ESP 32-CAM that I can’t seem to get working.
With a basic flash from ESPHome it comes online and and I can get to the device status page. (all the code below with the “esp32_camera” component commented out)
When I flash it with the “esp32_camera” component, it seems to connect for a bit but the connection goes dead. (log below the code) Have to flash it with the basic code with it connected to my laptop via serial to bring it back to life.
I’ve tried all the configurations shown on the Cam Component page but none of them work.
The only identifying thing on the board shows “ESP32-S” (image at bottom)
Any ideas how to get this thing up and running?
substitutions:
friendly_name: Printer Watch
esphome:
friendly_name: ${friendly_name}
name_add_mac_suffix: false
project:
version: '1.0'
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: !secret haapi_key
ota:
password: !secret ota_password
# Allow provisioning Wi-Fi via serial
improv_serial:
wifi:
ssid: !secret wifi_ssid
manual_ip:
static_ip: 10.0.0.131
gateway: 10.0.0.1
subnet: 255.255.255.0
dns1: 75.75.75.75
dns2: 75.75.76.76
fast_connect: off
ap:
ssid: "printer watch fallback"
password: !secret haapi_password
# In combination with the `ap` this allows the user
# to provision wifi credentials to the device via WiFi AP.
captive_portal:
dashboard_import:
package_import_url: github://esphome/example-configs/esphome-web/esp32.yaml@main
import_full_config: true
# Sets up Bluetooth LE (Only on ESP32) to allow the user
# to provision wifi credentials to the device.
esp32_improv:
authorizer: none
# To have a "next url" for improv serial
web_server:
switch:
- platform: restart
name: "Printer Watch Restart"
- platform: wifi_signal
name: "Printer Watch Signal Strength"
update_interval: 60s
text_sensor:
- platform: wifi_info
ip_address:
name: Printer Watch IP Address
ssid:
name: Printer Watch Connected SSID
bssid:
name: Printer Watch Connected BSSID
mac_address:
name: Printer Watch Mac Wifi Address
time:
- platform: homeassistant
esp32_camera:
external_clock:
pin: GPIO0
frequency: 20MHz
i2c_pins:
sda: GPIO26
scl: GPIO27
data_pins: [GPIO5, GPIO18, GPIO19, GPIO21, GPIO36, GPIO39, GPIO34, GPIO35]
vsync_pin: GPIO25
href_pin: GPIO23
pixel_clock_pin: GPIO22
power_down_pin: GPIO32
# Image settings
INFO Upload took 28.44 seconds, waiting for result...
INFO OTA successful
INFO Successfully uploaded program.
INFO Starting log output from 10.0.0.131 using esphome API
WARNING Can't connect to ESPHome API for esphome-web-c8a1d0 @ 10.0.0.131: Error connecting to [AddrInfo(family=<AddressFamily.AF_INET: 2>, type=<SocketKind.SOCK_STREAM: 1>, proto=6, sockaddr=IPv4Sockaddr(address='10.0.0.131', port=6053))]: [Errno 111] Connect call failed ('10.0.0.131', 6053) (SocketAPIError)
INFO Trying to connect to esphome-web-c8a1d0 @ 10.0.0.131 in the background
INFO Successfully connected to esphome-web-c8a1d0 @ 10.0.0.131 in 6.458s
WARNING esphome-web-c8a1d0 @ 10.0.0.131: Connection error occurred: esphome-web-c8a1d0 @ 10.0.0.131: Connection lost
