I’m trying to install ESPhome from Hass.io add-on store but it wont install for some reason…
I’m running a Raspi 3+ b with Hass.io I have Home Assistant 0.103.6 installed internet is via Ethernet cable and power is a 5v 3a supply
I have followed the instructions to the letter (as far as I know) and get as far as clicking “install” then the button fades, I get a progress circle for about 2 seconds and it all reverts back to normal… the instructions said it could take a while, so I left everything alone (thinking its working in the background) walked away from the computer and left it, watched some tv, came back about 2 hours later (plenty of time I thought) but still not installed… can anyone help me please?
thank you in advance
Robin
edit: I dont have ssh on the is pi as I dont need it so my config for ESPhome is empty… is that the problem? if so, what should I put in here?
Can you install portainer
Then you can check if there is a esphome image thats causing the issue, delete it, check the containers as well, then try again
portainer wont run just keep getting a 502 error, I’ve not got a lot of automatons and stuff set up yet so I’m thinking I’ll just do a fresh install of Hass.io and go from there, but thank you all for your help thus far I greatly appreciate it.
Not sure how old your install is/was, but 2 days ago hassos 3.8 came out. It’s much more stable from my experience compared to 3.7 (faster reboots, compiling esphome doesn’t crash, db sensors not failing after reboots, etc). Just wanted to mention in case you were reusing an older image. You shouldn’t have any issues installing esphome… maybe misconfiguring something the server fails to start, but not installing the addon sounds like something is corrupt.
edit: I 2nd that recommendation to install ssh. Just use the addon it’s easy, and 9/10 times when the webui fails after a config change, you can recover it through ssh. Also, sd card or usb ssd? I recommend investing in the latter now vs after the sd fails. You can still play/config while an ssd is in the mail, then just snap/download/restore on the ssd when it arrives.
Hi @Rdoull, from the look of that error, it seems like you’re trying to install esphome version 1.13.6. This is very wise, it’s a stable version.
However, installing an older version of esphome requires you to create a config in a little text box before you install, and I can’t help but think that maybe you’ve got a type or something there. Can you please post your esphome config here, even if its just one line, so we can take a look?
Same issue here! my log file:
20-02-01 07:55:11 ERROR (SyncWorker_18) [hassio.docker.interface] Can’t install esphome/esphome-hassio-armv7:1.14.3 -> 404 Client Error: Not Found (“no such image: esphome/esphome-hassio-armv7:1.14.3: No such image: esphome/esphome-hassio-armv7:1.14.3”).
