Hi
I’m setting up a nodemcu with ultrasonic sensor and some switches for lights control (via solid state relays).
Configuring seems to be ok. OTA update works fine.
I’m using the built-in mosquitto integration, hassio 90.1. Discovery is enabled
When I’m starting up, I get this:
INFO Reading configuration…
INFO Starting log output from 192.168.10.45 using esphomelib API
INFO Connecting to 192.168.10.45:6053 (192.168.10.45)
WARNING Couldn’t connect to API (Error connecting to 192.168.10.45: [Errno 111] Connection refused). Trying to reconnect in 1 seconds
WARNING Couldn’t connect to API (Error connecting to 192.168.10.45: [Errno 111] Connection refused). Trying to reconnect in 2 seconds
over and over again.
The switches don’t show up anywhere either.
The controller1 switches between online and offline quite often in the esphome dashboard.
The IP is correct (static), and I can ping it.
Help, please? Where can I start looking?
Helge
The config is like this:
esphomeyaml:
platform: ESP8266
board: nodemcuv2
wifi:
ssid: ‘XXX’
password: ‘xxxxx’
manual_ip:
static_ip: 192.168.10.45
gateway: 192.168.10.1
subnet: 255.255.255.0
mqtt:
broker: 192.168.10.40
logger:
api:
ota:
switch:
- platform: gpio
pin: D5
name: “Switch1” - platform: gpio
pin: D6
sensor: - platform: ultrasonic
trigger_pin: D1
echo_pin: D2
update_interval: 0.5s
filters:- filter_nan:
- unique:
- delta: 0.01
