This happened after trying to add support for my robot vacuum. But no matter what I do, I can’t get HA to use the automations.yaml.
There’s the standard
entry in the config file, but there’s also a remnant from the robovac config I was playing around with that I have been able to reduce to just:
automation:
if I remove that automation: line from the configuration.yaml file, the check configuration will just hang and I can’t even restart home assistant.
And with that line in the config file, all my actual automation that are stored in the automations.yaml file do not show up in the automations list.
Any ideas?
