Can't get inputs (binary_sensors) to properly control relays with Waveshare Modbus POE ETH Relay (C)
I recently got a couple of Waveshare Modbus POE ETH Relay (C) and tried, in different times, either to add one of them in configuration.yaml like the following example, or by installing the integration found at GitHub - icecoldfire/HomeAssistant-Waveshare-Relay: This is a custom integration for Home Assistant to control the Waveshare Modbus POE ETH Relay Board. It allows you to control relay channels and configure flash intervals directly from Home Assistant. after doing the required changes with VirCom accordingly.
homeassistant:
modbus:
  - name: ws-relay-1
    type: rtuovertcp
    host: wsrelay1.iot.internal
    port: 4196
    timeout: 9
    switches:
      - name: WS1-CH1
        slave: 1
        address: 0
        write_type: coil
      - name: WS1-CH2
        slave: 1
        address: 1
        write_type: coil
      - name: WS1-CH3
        slave: 1
        address: 2
        write_type: coil
      - name: WS1-CH4
        slave: 1
        address: 3
        write_type: coil
      - name: WS1-CH5
        slave: 1
        address: 4
        write_type: coil
      - name: WS1-CH6
        slave: 1
        address: 5
        write_type: coil
      - name: WS1-CH7
        slave: 1
        address: 6
        write_type: coil
      - name: WS1-CH8
        slave: 1
        address: 7
        write_type: coil
    binary_sensors:
      - name: WS1-DI1
        slave: 1
        address: 0
        input_type: discrete_input
        scan_interval: 1
      - name: WS1-DI2
        slave: 1
        address: 1
        scan_interval: 1
      - name: WS1-DI3
        slave: 1
        address: 2
        scan_interval: 1
      - name: WS1-DI4
        slave: 1
        address: 3
        scan_interval: 1
      - name: WS1-DI5
        slave: 1
        address: 4
        scan_interval: 1
      - name: WS1-DI6
        slave: 1
        address: 5
        scan_interval: 1
      - name: WS1-DI7
        slave: 1
        address: 6
        scan_interval: 1
      - name: WS1-DI8
        slave: 1
        address: 7
        scan_interval: 1
I’m getting different results when it comes to automations: in the first scenario, lights connected to WS1-CH1 will not turn immediatly but only after WS1-DI1 is pulled high for about 1.5s. Changing to a lower scan_interval causes this to stop working at all.
When using the integration, I can control channels and intervals directly from it, and see that timers are responding as buttons connected to DI are pressed, but if I create an automation and select, for example, timer 1 value change as condition and switch 1 toggle as action, nothing happens at all on button press.
Is this setup known to be broken/unreliable?
Is what I’m reading here agreeable?
Just to clarify, I’m running HAOS on Proxmox and the momentary switches used for testing this waveshare module are from btcino.
