Dear All,
I am having the same issue, can’t start home assistant with Let’s Encrypt. I am actually able to get the certificate.
The following in my Let’s Encrypt log,
"starting version 3.2.4
Saving debug log to /var/log/letsencrypt/letsencrypt.log
Processing /data/letsencrypt/renewal/1234qwer.duckdns.org.conf
Cert not yet due for renewal
The following certs are not due for renewal yet:
/data/letsencrypt/live/1234qwer.duckdns.org/fullchain.pem (skipped)
No renewals were attempted."
I read through the entire thread, tried difference combinations of port forwarding whether is 433->8123 or 8123->433, cancel the 80 -> 80, tried with and without https or 8123 in the configuration file, no luck.
http:
api_password: “1234qwer”
base_url: https://1234qwer.duckdns.org:8123
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
I can restart home assistant only if a delete the bottom 2 lines, the ssl lines. Any help would be appreciated. Thanks.
