Trying to get lifx set up, but I think im having issues. I followed the directions here, but have some quesitons.
I’m running kubernetes (if you don’t know what that is, just think docker/vms). with the following ips/subnets:
Host: 192.168.1.21 / 255.255.255.0
HASSIO container: 10.44.0.28/255.240.0.0
my lifx bulbs are on wifi, which is 192.168.2.0/255.255.255.0
In the HA config, I’ve tried
- platform: lifx
broadcast: 192.168.2.255
server: 192.168.1.21
But I’m not discovering any bulbs. the module loads fine though
2018-08-12 15:59:00 INFO (MainThread) [homeassistant.components.light] Setting up light.lifx
2018-08-12 15:59:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=light, service=lifx_set_state>
2018-08-12 15:59:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=light, service=lifx_effect_pulse>
2018-08-12 15:59:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=light, service=lifx_effect_colorloop>
2018-08-12 15:59:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=light, service=lifx_effect_stop>
2018-08-12 15:59:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=light, service=turn_on>
2018-08-12 15:59:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=light, service=turn_off>
2018-08-12 15:59:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_registered[L]: domain=light, service=toggle>
2018-08-12 15:59:00 INFO (MainThread) [homeassistant.setup] Setup of domain light took 7.5 seconds.
2018-08-12 15:59:00 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=light>
is there a way to do this? the container can ping 192.168.2.104 (my first light), and i am able to nmap UDP 56700 from the HA container, so it should work. I’ve also tried adding 255.255.255.255 as the broadcast, but i dont see any traffic for 56700 on my firewall. Is there a way to add bulbs individually by IP?
