Hi all, HADashboard is a brilliant idea to let my family members use Home Assistant with complete ease.
I have managed to make HADashboard work together with HASS on my RPi3. My Yeelight (dimmable light) works like a charm using hadimmer widget. However, I have another light connected to HASS via MQTT, with only on/off capability. It also works with hadimmer widget but I don’t want the +/- sign as they are useless obviously. So, I tried haswitch widget and it didn’t work.
So, my question is how to make a simple light with only on/off capability work. What widget and what settings should I use?
My apology if it’s a dumb question. I couldn’t find any answers or examples in the past few days.
first i want to point out that i think you are using the old HAdashboard.
there is a new and better version (V2) in beta at this moment.
but for now for your question i need to know what entity you are talking about.
if it is a light.something it wont work with switch.
if you want that you may want to create a templateswitch in HA or an input boolean that takes over the value from your light.
