Can't get lights to turn_on in dual-device DIY parking sensor
New Esphome / Hass user. I’ve been building wacky DIY devices in my garage with cheap Banggood parts to stave off the mounting insanity. It went okay.
I had great success building cover templates for my left and right garage doors, and, inspired, I set about to build a “Red Light / Green Light” sensor using LED’s (with 330 ohm resistors) inside ping-pong diffusers. The idea is that, as I back the car up into the garage, the proximity sensor on the back wall sends data to another esp32 device on the front (outside) wall, where I’ve got my door open/shut sensors (working great) and this wacky Red/Green led light contraption. When I’m “in position,” the green light will turn on. When I’m not there yet, or too close, it’ll be red. Eventually I have plans to use flashing frequency to indicate how close I am, but let’s not rush into anything just yet. I’ll be pleased as punch if I can just turn the darned things on and off with the sensor.
The red/green LED lights work fine when I control them through Lovelace. They don’t look anywhere near as cool as they do online. Don’t cheap out on those ping pong balls, folks.
The conditions on the proximity sensor are firing correctly - I can see periodic “The car is in position” or “The car is too close or too far” messages in my logs for the door_opener device (that sits on the back wall, connected to the garage door switches, and the proximity sensor).
However, no matter what I do, I cannot manage to turn_on the red/green LED lights from my automation, although I’m quite sure things work right up until that exact moment. I’m clearly missing out on something, and I’m hoping some kind soul here can set me right.
Here goes:
door_sensor device - PIR sensor, left/right door sensors, Red / Green LED’s
binary_sensor:
  # The sensor to detect the state of the door (not exposed to ha)
  - platform: gpio
    pin:
      number: GPIO19
      mode: INPUT_PULLUP
    name: "Garage Door Sensor Left"
    filters:
      - delayed_off: 50ms
  - platform: gpio
    pin:
      number: GPIO18
      mode: INPUT_PULLUP
    name: "Garage Door Sensor Right"
    filters:
      - delayed_off: 50ms
  - platform: gpio
    pin: GPIO23
    name: "Garage PIR Sensor"
    device_class: motion
  - platform: homeassistant
    entity_id: sensor.car_sensor
output:
  - platform: ledc
    pin: GPIO22
  - platform: ledc
    pin: GPIO21
light:
  - platform: monochromatic
    output: garage_redlight
    name: "Garage Red Light"
    default_transition_length: 0s
    output: garage_greenlight
    name: "Garage Green Light"
door_opener device - two-channel relay, proximity sensor
switch:
  # The GPIO pin which controls the relay to toggle the garage (not exposed to ha)
  - platform: gpio
    pin: GPIO33
    restore_mode: ALWAYS_OFF
  # The Switch that toggles the garage when turned on (exposed to ha)
    name: "Left Garage Door Switch"
    turn_on_action:
    - switch.turn_on: relay_left
    - delay: 400ms
    - switch.turn_off: relay_left
  - platform: gpio
    pin: GPIO32
    internal: false
    name: "Right Garage Door Switch"
    turn_on_action:
    - switch.turn_on: relay_right
    - delay: 400ms
    - switch.turn_off: relay_right
  - platform: ultrasonic
    trigger_pin: GPIO27
    echo_pin: GPIO26
    update_interval: 0.5s
    on_value:
      then:
        - if:
            condition:
              binary_sensor.is_on: ha_right_garage_door
            then:
              - logger.log: "The right garage door is open."
              - if:
                  condition:
                    sensor.in_range:
                      above: .80
                      below: .95
                  then:
                    - logger.log: "The car is in position."
                    - homeassistant.service:
                        service: light.turn_on
                          entity_id: garage_green_led_light
                        service: light.turn_off
                          entity_id: garage_red_led_light
                  else:
                    - logger.log: "The car is too close or too far."
            else:
              - logger.log: "The right garage door is closed."
binary_sensor:
    name: "Input Boolean From Home Assistant"
    entity_id: binary_sensor.garage_door_sensor_right
I’ve cobbled this together from watching others’ and so far I’ve been able to work through things, but I’m worried I’m missing something fundamental that I’ll keep spinning my wheels on if I don’t reach out to ask for help.
Here’s a logfile from door_opener:
[21:27:58][D][ultrasonic.sensor:029]: 'Car Sensor' - Got distance: 0.89 m
[21:27:58][D][sensor:092]: 'Car Sensor': Sending state 0.88580 m with 2 decimals of accuracy
[21:27:58][D][main:363]: The right garage door is open.
[21:27:58][D][main:374]: The car is in position.
[21:27:58][D][sensor:092]: 'Car Sensor': Sending state 0.89008 m with 2 decimals of accuracy
[21:27:59][D][ultrasonic.sensor:029]: 'Car Sensor' - Got distance: 0.89 m
[21:27:59][D][sensor:092]: 'Car Sensor': Sending state 0.89043 m with 2 decimals of accuracy
[21:27:59][D][main:363]: The right garage door is open.
[21:27:59][D][main:374]: The car is in position.
It all seems good from there, except for the part where it doesn’t turn the light on.
There are some vestiges in the code of things I’d tried out but abandoned that I haven’t cleaned up yet (like the HA sensor on the door_sensor device reading the proximity). Sorry if this is a noob question or rookie mistake - I appreciate any help in advance.
