Hi, I got a new NUC to use as my primary HA server. I will be keeping my older HA server running on a VM on my Synology NAS. so far I managed to move all necessary things to the new server except for the LocalTuya.
My new server has:
Any idea how to get it to work? Thanks RS
How did you moved ? , and what doesn’t work with moving Local_tuya ?
Tuya devices support only 1 active connection at a time, so you have to disable old integration to start using the new one.
Yep, that’s it… Just turned off my old server and worked the installation and all went smooth.
Thank you
Fresh clean setup while still having the old server up.
