Cant get my first custom integration to work (took help from Chat GPT)
Would appriciate some helt with my first custom integration. I have programming experience but I’m new to HA and Python. So i tried to create the framework using ChatGPT (3.5 as 4 is not avalible), my thinking was to write the logic by my self after this.
What i try to accomplish is to read attributes from another sensor(Nordpool), make calculations and publish 2 states and a lot of attributes.
I have set “debug” state for this “energy_management” component in the log settings and when starting up i get the following errors in the log file:
2023-12-05 10:18:58.783 ERROR (MainThread) [homeassistant.setup] The energy_management integration does not support YAML setup, please remove it from your configuration
2023-12-05 10:18:58.783 ERROR (MainThread) [homeassistant.setup] Setup failed for custom integration energy_management: No setup or config entry setup function defined.
I have defined the custom component as a sensor and use async, is this the best setup?
I have done what i can with my very limited knowlege, would highly appriciate some guidence of how to proceed.
I added the following line in the configuration.yaml:
energy_management:
Files i have:
init.py is empty
manifest.json
    "domain": "energy_management",
    "name": "Energy Management",
    "documentation": "https://your-documentation-link-here.com",
    "dependencies": [  ],
    "codeowners": [  ],
    "requirements": [  ],
    "version": "0.1.0",
    "config_flow": false,
    "autoload": true,
    "state": ["sensor"],
    "zeroconf": ["_energy-management._tcp.local."],
    "homeassistant": [
        "domain": "sensor",
        "icon": "mdi:flash",
        "device_class": "energy",
        "config_entries": [
            "title": "Energy Management Configuration",
            "description": "Configure the Energy Management component.",
            "ha_version": "0.110.0",
            "requirement": "sensor",
            "entry_class": "config_entries.ConfigEntry",
            "entry_description": "Configuration for the Energy Management component.",
            "entry_title": "Energy Management",
            "entry_id": "config_entry_id",
            "source": "config_entry",
            "connection_class": "local_push"
        "suggested_area": "Living Room"
sensor.py
import asyncio
from datetime import datetime, timedelta
from homeassistant.helpers.entity import Entity
DOMAIN = "energy_management"
async def async_setup_platform(hass, config, async_add_entities, discovery_info=None):
    async_add_entities([EnergyManagementSensor()])
class EnergyManagementSensor(Entity):
    def __init__(self):
        self._state = None
        self.block_heating_pump = 1  # Renamed to "block_heating_pump"
        self.electricity_hours = 0
        self.electricity_price = []
    async def async_added_to_hass(self):
        await self._update_state()
        await self._schedule_next_update()
    async def _update_state(self):
        nordpool_sensor = self.hass.states.get("sensor.nordpool_kwh_se3_sek_3_10_0")
        tomorrow_valid = nordpool_sensor.attributes.get("tomorrow_valid", False)
        if tomorrow_valid:
            self.electricity_hours = 47
        else:
            self.electricity_hours = 23
        self.electricity_price = nordpool_sensor.attributes.get("raw_today", [])
        if self.electricity_hours == 47:
            self.electricity_price += nordpool_sensor.attributes.get("raw_tomorrow", [])
        # Copy and modify the electricity_price array
        battery_state_plan = [list(row) for row in self.electricity_price]
        for row in battery_state_plan:
            row[1] *= 2  # Multiply the "value" column by 2
        # Store battery_state_plan as an attribute
        self.attributes = {"battery_state_plan": battery_state_plan}
        # Renamed state "additional_state" to "block_heating_pump"
        # Check the current hour without minutes and seconds
        current_hour = datetime.now().replace(minute=0, second=0, microsecond=0).strftime("%H:%M:%S")
        # Find and store corresponding "value" for the selected hour
            if row[0] == current_hour:
                self._state = row[1]
                break
    async def _schedule_next_update(self):
        now = datetime.now()
        next_hour = (now + timedelta(hours=0)).replace(minute=1, second=00, microsecond=0)
        time_until_next_hour = (next_hour - now).total_seconds()
        self.hass.async_create_task(
            asyncio.sleep(time_until_next_hour).then(self._update_and_schedule)
    async def _update_and_schedule(self, _):
        self.async_write_ha_state()
all looks weird to me :slight_smile: I would look at a basic integration or an existing cookie cutter template.
Many thanks fuatakgun for checking the code!
Clearly ChatGPT still has a lot to learn. I will do it the hard/normal way without shortcuts. I have made a development installation in Docker now and will start with the simple examples in the links you provided
Remember that the latest training data for ChatGPT is from September 2021. That is a very long time for the Python development and especially Home Assistant world :wink:
