I realy don’t know what is wrong with my configuration - part of my automations work, mostly those which turn something off… can somebody tell me where’s the error?
devices:
Sonoff switch with AFE Firmware, configured with MQTT
switch.swc_choinka: for switching lights on and off. MQTT platform, topic, payload etc. everything configured correctly [works if switched on/off manually]
binary_sensor.bns_nest_away: correctly configured with value_template: “{{ is_state_attr(‘climate.living_room_salon’, ‘away_mode’, ‘on’) }}” [when checked in “states” browser - shows correct values]
group.grp_domownicy: people tracked via nmap and gpslogger, when someone’s at home - shows correct “home” value
notify.huncbot: telegram bot configured with broadcast mode, just for testing - I wanted to be double-sure that automation is fully run
what I want:
turn on lights AFTER 7:30am but BEFORE 1:00am, if nest “away” mode is off and/or if somebody is at home, but ONLY between 15th December and 15th January, then tell me about it via telegram
and now automation config - turning on the lights DOESN’T work, I don’t know why…
alias: turn_on_the_lights
- platform: state
entity_id: binary_sensor.bns_nest_away
to: "off"
- platform: time
at: "07:30:00"
- platform: state
entity_id: group.grp_domownicy
to: 'home'
condition:
condition: and
conditions:
- condition: template
value_template: '{{ ( now().month == 12 and ( now().day >= 15 )) or ( now().month == 1 and now().day <= 15 ) }}'
- condition: time
before: "01:00:00"
- condition: or
conditions:
- condition: state
state: "off"
- condition: state
state: 'home'
- service: switch.turn_on
entity_id: switch.swc_choinka
- service: notify.huncbot
message: 'lights are now ON!'
and configuration for turning the lights OFF - works good:
alias: turn_off_the_lights
value_template: "{{ is_state_attr('climate.living_room_salon', 'away_mode', 'on') }}"
### ^^^ first I've tried another way of testing the away settings
### where "living_room_salon" is the name of my main nest thermostat
### - both gives good answer in the state browser
### but so there's no special difference which one I use
- platform: time
at: "01:00:00"
- service: switch.turn_off
message: 'lights are OFF now!'
I gave up, don’t know what I did wrong… why turning the lights is not working?
Can I just confirm these are either in separate files merged as a list, or if they’re in the same file you do have a hyphen before the word alias on both? If not that’s the problem.
If so there’s a conflict with your triggers and conditions so they’re always not true.
I suspect the conditions, but nothing immediately jumps out at this time of night. Comment them out and reintroduce them one by one until it stops working.
oh, yes, I forgot to mention that - all automations are in separate files, merged with
automation: !include_dir_list automations/
so I guess, that hyphen before alias isn’t needed at all?
and as I’m still relatively new with home assistant [been playing “seriously” for about a week or two now], I need to ask one additional thing, just to clear my doubs out:
when adding triggers, ANY of them alone, can start the action and there is no need to all of the triggers be positive, right?
Yeah, they’re effectively added by the include, so that’s not your issue.
Yeah, triggers are like an ‘or’, so it will trigger as and when each of them occur. Hence why I suspect it’s the conditions that are the problem but I’ll be honest I scanned your post for ages trying to find the conflict and it beat me. I’m hoping it’s just tired eyes and not me losing my touch
As I say, comment them out and reintroduce them one at a time. Or another thing I sometimes do is write the logic of the conditions down and pick through it one by one with a load of whitespace between each one to make sure it matches what I’ve written down before removing the whitespace again. Random, but it’s worked a few times. Hard to spot errors in large chunks of text
thanks for fighting this battle with me at such an unhuman part of the day [it’s 1am at my place ;)]
yep, will try, tomorrow probably. today just few more tweaks in dashboard and it’s time to bed
aaaargh, true. I need to rethink that then… THANKS!.. but - I’ve got another automation, which looks almost the same - just without the “after 7:30” and… it’s not working anyway ;( gotta try to comment them out as you said, and play with one at a time. will check it and report tomorrow
@anon43302295 - just like you wrote, time condition needed to be changed.
while for humans it’s easy to think about “the time between 7am and 1am” [we can consider it simply as one long day], home assistant can’t deal with that out of the box. so after few trials and errors, instead of tinkering the way to recognize 1am as the end of the day [counted after 7am], I just thought, that I really don’t need to make a time condition “before 1am”…
another automation already turns off lights at 1am, and there is a very little chance, that my home between midnight and 1am will be empty and waiting for someone to come back in that very hour, so I just simply changed te “before” time:
- condition: time
after: "07:30:00"
before: "23:59:00"
tested with different hours [like: now ;)] and works fine. so I guess tomorrow morning, the lights should be on, when I’ll get up
…and that little change costed me earlier few hours of looking at the code and understanding nothing…
