Can't get new 0.66.1 install to start
I returned from holiday to find my hassio was not running and would not respond :frowning:
Decided to reflash with 0.66.1 and got the splash screen so left it for an hour or more.
However hassio.local:8123 then reported site cannot be reached, so I have ssh into resinOS and extracted the log below with docker logs resin_supervisor
starting version 3.2.4
18-04-03 12:55:35 INFO (MainThread) [__main__] Initialize Hassio setup
18-04-03 12:55:35 INFO (MainThread) [__main__] Setup HassIO
18-04-03 12:55:35 INFO (SyncWorker_0) [hassio.docker.supervisor] Attach to supervisor homeassistant/armhf-hassio-supervisor with version 0.99
18-04-03 12:55:35 INFO (MainThread) [hassio.misc.host_control] Send 'info' to HostControl.
18-04-03 12:55:38 INFO (MainThread) [hassio.misc.host_control] Receive from HostControl: { "type": "resinos", "version": "1.3", "last_version": "1.3", "hostname": "hassio", "features": ["shutdown", "reboot", "update", "hostname"], "os": "GNU/Linux" }.
18-04-03 12:55:38 INFO (SyncWorker_1) [hassio.docker.interface] Attach to image homeassistant/raspberrypi3-homeassistant with version 0.66.1
18-04-03 12:55:38 INFO (MainThread) [hassio.addons.git] Load addon /data/addons/git/a0d7b954 repository
18-04-03 12:55:38 INFO (MainThread) [hassio.addons.git] Load addon /data/addons/core repository
18-04-03 12:55:38 INFO (MainThread) [hassio.addons] Load addons: 32 all - 32 new - 0 remove
18-04-03 12:55:38 INFO (MainThread) [hassio.updater] Fetch update data from https://raw.githubusercontent.com/home-assistant/hassio/master/version.json
18-04-03 12:55:39 INFO (MainThread) [hassio.snapshots] Found 0 snapshot files
18-04-03 12:55:39 INFO (MainThread) [hassio.addons] Startup initialize run 0 addons
18-04-03 12:55:39 INFO (MainThread) [__main__] Run HassIO
18-04-03 12:55:39 INFO (MainThread) [hassio.misc.dns] Start DNS port forwarding for host add-ons
18-04-03 12:55:39 INFO (MainThread) [hassio.core] Ignore Hass.io auto updates on dev channel
18-04-03 12:55:39 INFO (MainThread) [hassio.core] Start API on 172.30.32.2
18-04-03 12:55:39 INFO (MainThread) [hassio.core] Hass.io reboot detected
18-04-03 12:55:39 INFO (MainThread) [hassio.tasks] All core tasks are scheduled
18-04-03 12:55:39 INFO (MainThread) [hassio.core] Hass.io is up and running
18-04-03 12:55:54 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home-Assistant docker!
18-04-03 12:55:54 INFO (SyncWorker_3) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant docker application
18-04-03 12:56:09 INFO (SyncWorker_3) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.66.1
18-04-03 13:06:10 WARNING (MainThread) [hassio.homeassistant] Don't wait anymore of Home-Assistant startup!
18-04-03 13:06:24 WARNING (MainThread) [hassio.tasks] Watchdog found a problem with Home-Assistant docker!
18-04-03 13:06:24 INFO (SyncWorker_3) [hassio.docker.interface] Clean homeassistant/raspberrypi3-homeassistant docker application
18-04-03 13:06:33 INFO (SyncWorker_3) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.66.1
Which seems to suggest that there is an issue starting homeassistant.
I can see there is the end of what looks like an error, but how to get the start of the message to find the cause ?
root@hassio:/# docker logs homeassistant
  File "/usr/lib/python3.6/runpy.py", line 193, in _run_module_as_main
    "__main__", mod_spec)
  File "/usr/lib/python3.6/runpy.py", line 85, in _run_code
    exec(code, run_globals)
  File "/usr/lib/python3.6/site-packages/homeassistant/__main__.py", line 371, in <module>
    sys.exit(main())
  File "/usr/lib/python3.6/site-packages/homeassistant/__main__.py", line 346, in main
    args = get_arguments()
  File "/usr/lib/python3.6/site-packages/homeassistant/__main__.py", line 84, in get_arguments
    import homeassistant.config as config_util
  File "/usr/lib/python3.6/site-packages/homeassistant/config.py", line 25, in <module>
    from homeassistant.util.yaml import load_yaml, SECRET_YAML
  File "/usr/lib/python3.6/site-packages/homeassistant/util/yaml.py", line 11, in <module>
    import keyring
  File "/usr/lib/python3.6/site-packages/keyring/__init__.py", line 3, in <module>
    from .core import (set_keyring, get_keyring, set_password, get_password,
  File "/usr/lib/python3.6/site-packages/keyring/core.py", line 13, in <module>
    from . import backend
  File "/usr/lib/python3.6/site-packages/keyring/backend.py", line 12, in <module>
    import pkg_resources
  File "/usr/lib/python3.6/site-packages/pkg_resources/__init__.py", line 3017, in <module>
    @_call_aside
  File "/usr/lib/python3.6/site-packages/pkg_resources/__init__.py", line 3003, in _call_aside
    f(*args, **kwargs)
  File "/usr/lib/python3.6/site-packages/pkg_resources/__init__.py", line 3030, in _initialize_master_working_set
    working_set = WorkingSet._build_master()
  File "/usr/lib/python3.6/site-packages/pkg_resources/__init__.py", line 650, in _build_master
    ws = cls()
  File "/usr/lib/python3.6/site-packages/pkg_resources/__init__.py", line 643, in __init__
    self.add_entry(entry)
  File "/usr/lib/python3.6/site-packages/pkg_resources/__init__.py", line 699, in add_entry
    for dist in find_distributions(entry, True):
  File "/usr/lib/python3.6/site-packages/pkg_resources/__init__.py", line 2023, in find_on_path
    path_item, entry, metadata, precedence=DEVELOP_DIST
  File "/usr/lib/python3.6/site-packages/pkg_resources/__init__.py", line 2432, in from_location
    py_version=py_version, platform=platform, **kw
  File "/usr/lib/python3.6/site-packages/pkg_resources/__init__.py", line 2772, in _reload_version
    md_version = _version_from_file(self._get_metadata(self.PKG_INFO))
  File "/usr/lib/python3.6/site-packages/pkg_resources/__init__.py", line 2397, in _version_from_file
    line = next(iter(version_lines), '')
  File "/usr/lib/python3.6/site-packages/pkg_resources/__init__.py", line 2565, in _get_metadata
    for line in self.get_metadata_lines(name):
  File "/usr/lib/python3.6/site-packages/pkg_resources/__init__.py", line 1471, in get_metadata_lines
    return yield_lines(self.get_metadata(name))
  File "/usr/lib/python3.6/site-packages/pkg_resources/__init__.py", line 1468, in get_metadata
    return value.decode('utf-8') if six.PY3 else value
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xe3 in position 3: invalid continuation byte
Any help much appreciated !
Kev
