I’m using HA 2023.1.2 with Zigbee2MQTT and a Sonoff USB 3.0 Dongle Plus. I have a Philips Hue Dimmer Switch and a Philips Hue bulb on the Zigbee network and I’m using a Node Red automation to control the button presses on the remote to control the bulb.
I don’t have a Hue hub, so I have a very simple automation that says when the power button on the remote is pushed, call the light.toggle service of the light.
The issue is that the light will go on/off for a brief instant, and then revert back to its original state. This only happens the first time I push the button. If I press it a 2nd time, it works properly. My wife approval factor has plummeted as a result!
I tried changing the automation to something other than light.toggle. I made one that says "if light is on, call light.turn_off - if light is off, call light.turn_on’. I get the same behavior!
Anybody know what’s going on?
