Sorry for the technically duplicate post, but the first place I asked it wasn’t really the right place. O.P: https://community.home-assistant.io/t/push-notifications-now-available/154700/166?u=dave_sausages
I can’t for the life of me get the push notifications to work.
These are my steps:
Install and open android app.
Phone is on same wifi as Home Assistant
App says “unable to find home assistant”
Enter address manually: I put the Nabu Casa url in then my user account login details.
App says: “Unable to register application. Please check to ensure you have the mobile_app integration enabled on your home assistant instance”
Retry does nothing. However, I close app re-open it and it loads HA lovelace up instantly.
On my laptop, there is no “ notify.mobile_app” service in Developer tools – Services. Only notify.notify
I Restart HA and still no notify.mobile_app in the services.
It should be noted that when I go to integrations and try to add the mobile app integration, it says: Aborted - Open the mobile app to set up the integration with Home Assistant. See the docs for a list of compatible apps.
I’ve tried pretty much every version of “open app once” and clear data etc as per the instructions, but still no dice. I’ve logged in on the app and kept it on the “unable to register application” screen and restarted HA there for example. Still same problems.
I have cleared the android app cache, reinstalled it multiple times, but nothing I try gets the notify.mobile service to appear.`
App is version 1.4. Hassio on Rpi4 0.104.2
Can anyone help get this working for me?
I suppose the first stage of problem solving is: should I get the “Unable to register application. Please check to ensure the mobile_app integration enabled on your home assistant instance” error when I first try to correct to my HA instance on the app?
When I try to connect for the first time I get this appear my logs:
Error handling request
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_protocol.py", line 418, in start
resp = await task
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_app.py", line 458, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.7/site-packages/aiohttp/web_middlewares.py", line 119, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/real_ip.py", line 39, in real_ip_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 72, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 135, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 123, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 50, in wrapper
result = await method(view, request, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/mobile_app/http_api.py", line 80, in post
DOMAIN, data=data, context={"source": "registration"}
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 109, in async_init
result = await self._async_handle_step(flow, flow.init_step, data)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 172, in _async_handle_step
result: Dict = await getattr(flow, method)(user_input)
File "/usr/src/homeassistant/homeassistant/components/mobile_app/config_flow.py", line 47, in async_step_registration
self.hass, user_input[CONF_USER_ID], devt_entry.entity_id
File "/usr/src/homeassistant/homeassistant/components/person/__init__.py", line 108, in async_add_user_device_tracker
if device_tracker_entity_id in device_trackers:
TypeError: argument of type 'NoneType' is not iterable
If you go to integrations, do you see anything under mobile_app?
