I just recently got a summer house and have setup an Ubuntu server running HAOS in a VM. This is my secondary instance. I have used the “Cloudflare setup” (and own domain) to be able to access it remotely. It all works fine with the companion app and web access from home.
At home I run my main instance of HAOS in a VM on a NAS, here I use the “Duck DNS/NGINX combination” to access it remotely. It works fine. I might change to the “Cloudflare setup” in the future to have the two instances aligned.
Now I would like to be able to see sensors and such from my secondary instance of HA at my main instance HA at home.
For this I have installed the Remote Home-Assistant add-on on both instances and followed the guides (I guess) correctly;
On the secondary instance of HA I created an Access token, edited the configuration.yaml and setup the Remote Home-Assistance integration as a remote instance.
On the main instance of HA I setup the Remote Home-Assistance to add a remote instance and put in the necessary information.
The “circle” spins for a good while and then I get the error message “Failed to connect to server”. I tried remove the checkboxes for Secury and Verify SSL, but without any luck. I tried to add “https://” in front of the host name. Also both instances have been re-started.
Any ideas what can be wrong and/or suggestion/or troubleshooting on how to get this working?
