Hello everybody, i’m new here!
Have been playing with Hassio for a couple weeks now and am well on my way to automating my house.
Up untill now just reading all the infrmation on here was more then enough to keep me going, but now i’m completely stuck
I’m trying to get rfxtrx working, have read every possible thread on this forum and the entire internet (i think), but still no luck
Hardware:
- Raspberry Pi 4, 4GB model
- RFXtrx433XL
Software: - Latest Hassio, Home Assistant 0.101.0
core-ssh:~# dmesg | grep FTDI
[ 1.694748] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 1.694869] ftdi_sio 1-1.1:1.0: FTDI USB Serial Device converter detected
[ 1.696699] usb 1-1.1: FTDI USB Serial Device converter now attached to ttyUSB0
core-ssh:~# ls -al /dev/serial/by-id
total 0
drwxr-xr-x 2 root root 80 Oct 31 17:55 .
drwxr-xr-x 3 root root 60 Oct 31 17:55 ..
crw-rw---- 1 root audio 166, 0 Oct 31 17:55 usb-0658_0200-if00
crw-rw---- 1 root audio 188, 0 Oct 31 17:55 usb-RFXCOM_RFXtrx433XL_DO462DW8-if00-port0
My configuration.yaml looks like this
rfxtrx:
device: /dev/serial/by-id/usb-RFXCOM_RFXtrx433XL_DO462DW8-if00-port0
debug: true
dummy: false
switch:
platform: rfxtrx
automatic_add: true
- I’ve also treid /dev/ttyUSB0 for the device path, also without any luck.
- Rebooted the entire Pi multiple times
- Tried different USB ports, even with a powered USB hub
- Tried pushing buttons on my 433Mhz remote/switches
- Checked my config for errors
Still… nothing
The Hassio logs look normal, no errors, but also no mentions of rfxtrx or USB devices. It’s like it’s not even trying to load the rfxtrx integration
So, here i am, asking for help. Is there anybody out there that got this particular piece of hardware working on Hassio? Note: It’s the newest RFXCOM, the RFXtrx433XL
Thanks in advance,
Jasper
