Can't get rid of automation - only automations in automations.yaml are editable
Having trouble and trying to simplify things and get back to a known working configuration.
Trying to get rid of my only automation, but I can’t get rid of the automation - Error - only automations in automations.yaml are editable. If I try to delete, Can’t get rid of automation - only automations in automations.yaml can be deleted.
Please help. Very new at this and experiencing a lot of frustration.
Same problem here.
“Enkel automatiseringen in automations.yaml kunnen verwijderd worden”
Same problem here. In fact, this is exactly the kind of mess I warned people about years ago when they started GUIfying every configuration item. The result is an indeterminate state where the GUI won’t let you delete an entity that is not in any of the YAML files and is wreaking havoc in the real world.
Same mess if I try to disable it. As soon as home assistant restarts, the automation reactivates. How do we fix this?
I would add that the Migrate button also doesn’t work. Is there any way to delete these automations if the GUI refuses to do anything useful? At least with YAML it’s either there or it isn’t.
See Unhelpful message "Only automations in automations.yaml can be deleted." · Issue #18631 · home-assistant/frontend · GitHub
Maybe I was able to get rid of those undeletable/uneditable automation dashboard entries by doing the following:
Web interface > Developer tools > select tab “YAML” > under section “YAML configuration reloading”, click “ALL YAML CONFIGURATION”.
If it’s still actual:
I got rid off these automations by creating some dummy automations with the same names in automations.yaml, restarted HA, deleted them in the yaml again and restarted HA again. After that they were gone.
I tried 4 or 5 proposed solutions before this and this was the only thing that worked. That and I think it would have worked for the people who posted and got those other 4 or 5 responses too. Thank you very much!
Yep - this worked for me - Thank you @nephrotranz !
Edit: However you have to be very careful, I managed to delete another automation with a similar name. Fortunately I had a recent backup.
Another way that worked for me is to check traces, you can see that it is yet in HA’s memory.
Create an empty automation in automation.yaml with the same id and then restart HA with Quick reload.
You can see that the automation has a red icon now and you can delete it safely.
Man, this is killing me. I tried adding and deleting entries with the same name to no avail. Can’t “migrate.” Automations.yaml is empty.
I get an automation 8 (and several others) that just won’t go away.
I found references to this automation in these files:
.storage/homeassistant.exposed_entities
.storage/core.restore_state
.storage/core.entity_registry
But even manually editing them to remove references to this automation doesn’t work (shutting down hass first, then restarting afterwards).
There must be a reference in the database somewhere?
I tried getting their unique_id from those files and making a dummy automation with the same name and unique_id – no luck, I can delete the new one but nothing changes with the old one (in spite of hard refreshes, “reload UI,” and restarting hass completely).
What a pain. Anyone have any other ideas?
EDIT: As is often the case, after digging through a bunch of postgres stuff in the database, I eventually discovered this was just user error. I had multiple automations being included from a separate file. These automations did not include an “alias,” so they got assigned a default name, e.g. automation_8, but this string appeared nowhere in my yaml configs which is why I didn’t find it with e.g. grep. Removing them was as simple as editing the yaml.
I had the same problem. Migrating the automation actually added the automation to automations.yaml, leaving me with two identical automations. After some digging around I found the original automation in a file in the packages directory. Deleting that file solved the problem for me.
This works great for instantly getting rid of automations that have the “Only automations in automations.yaml can be deleted” message. I don’t know why it works, but it does!
I WORKED!! Thank you very much @automatted Matt. Just 2 clicks and it gone for good.
