Can't get sensor to act as binary
Hi Justin, yep my old and new values seem to be changing from False to True as they should, and state is changing from off to on, etc:
2017-09-10 01:24:57.475 Detail, Node002, Refreshed Value: old value=false, new value=true, type=bool
2017-09-10 01:24:57.475 Detail, Node002, Changes to this value are not verified
2017-09-10 01:24:57.475 Detail, Node002, Notification: ValueChanged
2017-09-10 01:25:00.820 Detail, Node002,   Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x02, 0x03, 0x30, 0x03, 0x00, 0xc0
2017-09-10 01:25:00.820 Info, Node002, Received SensorBinary report: Sensor:192 State=Off
2017-09-10 01:25:00.821 Detail, Node002, Refreshed Value: old value=true, new value=false, type=bool
2017-09-10 01:25:00.821 Detail, Node002, Changes to this value are not verified
2017-09-10 01:25:00.821 Detail, Node002, Notification: ValueChanged
sorry I can’t be of more help
Thanks for this @alltherage
So in the end I removed the sensor from the door, played with it a bit (and everything worked) and then remounted it to the door frame, and it all seems to work fine now? I don’t know if it was misaligned (hard to see how though)? Either way, thanks for the reply, you inspired me to try further and get it working!
ah I’m glad! :slight_smile:
Guys I have spent literally hours and hours trying to get my Aeotec Recessed Door Sensors to work to no avail. Finally stumbled upon this post via a link from another post and now all is working perfectly!
Thank you so much! :grinning:
I’m having the same exact problem as you mentioned but I can’t seem to get this to work. I’ve tried everything mentioned here … the sensor won’t get out of sleep mode.
Hi in the end the issue was that I wasn’t having success in changing my sensor to a binary one because my sensor was always asleep when I was trying to implement the change.
I woke the sensor by holding the button on it for 6 seconds, then changed it to binary immediately afterwards and this time it stuck! Basically you need to wake the device before doing anything to it.
Hope this helps!
I was messing with this for the last 6 hours and between a few threads I was able to get the sensor into a mode that reported many variables rather than one sensor. I think I pressed the tiny button for like 20 seconds, then restarted HA. I also tried setting 121 to 4, or 8. Neither of those worked. Set parameter 121 to 16. With that, the “binary_sensor.aeotec_recessed_door_sensor_gen5_sensor” went from always on to changing with the magnet. Then I could get that info into an if/then/else setup in the configuration.yaml so I could make clean sense of the sensor in Lovelace. Ask if you’ve got questions, but 16 is the answer I found somewhere kind of unrelated. Second post by the taco.
Hi, I’m not sure if this is the place to ask. I have a Z-Wave, mulitsensor. I can see the ‘door sensor’ (I’m using it for a window) trigger for open/close. When it’s open it returns 22, closed returns 23. Can I set it so it displays “Open” and “Closed” instead. Is that something I do on the front end or is part of Z-Wave?
Thanks,
