Hi all,
I’m struggling with Seven Segments to perform image recognition even on a static file. I’ve tried from the UI and from the command line on HA OS. I’ve gone through the main guide and got the component show up in the UI but never got any values despite trying with various files.
Did some troubleshooting as per https://community.home-assistant.io/t/seven-segments-extra-arguments-formatting/59848/3 to try to display the processed images, but with no luck. The interim file is not created at all nor the values show up. Most likely the processing fails, so this got me thinking whether the SSOCR is implemented in Alpine at all?
Digging further, I’ve done manual SSOCR build+install on HA OS and it works from the command line just like it does in terminal on my other laptop (macbook). However, still not working in the UI and after the docker is built again, all changes are lost.
Anyone got the SSOCR working with HA OS or has any idea how to get it working? Or am I missing something?
My config just in case:
sensors:
power_meter:
value_template: "{{ states('image_processing.sevensegment_ocr_seven_segments') }}"
friendly_name: 'GigaJoule'
unit_of_measurement: 'GJ'
#input file to be recognised
camera:
- platform: local_file
file_path: /config/www/images/img_2.jpg
#interim file to verify recognition
file_path: /config/www/images/img_2_processed.jpg
image_processing:
- platform: seven_segments
source:
- entity_id: camera.seven_segments
extra_arguments: remove_isolated erosion 3 -Dimg_2_processed.jpg
