Can't get slack message to send with image attached
I’m trying to create an automation for when my reolink doorbell is pressed, I get a slack message with a preview of the front door. I’ve got the following;
  - service: notify.unraid
      message: Someone is at the front door
      title: Someone is at the front door
      target: "#doorbell"
        file:
          path: /config/temp/snapshot.jpg
Running this, I get nothing in slack. As soon as I take out the last 3 lines to do with the file path, I get the message through fine but obviously without the image.
I have an action before this to create a camera snapshot into that location and I’ve confirmed the file has been created, and that the image opens fine.
What am I doing wrong?
Managed to sort it after reading the logs. The bot needed the ‘files:write’ role in slack.
FYI since google comes here. This API is being deprecated by slack and currently there is no workaround, but there is an open ticket here Method deprecated for file-based message: SlackApi · Issue #121672 · home-assistant/core · GitHub
