Cant get started
Followed the set up instructions…
Not working.
I flashed the proper image to the SD card, and inserted in the Pi. I plugged the pie into the router via a LAN port/ cord. The router recognizes the Pi, but the home assistant doesnt load. I tried using the local address per instructions and when that didn’t work, I used the ID IP address from the routers listing. The program doesnt load. Any thoughts what went wrong?
What means “doesn’t load”?
Does the hass.io logo show up in the browser?
If you can’t find the IP, you can download some IP Scanner for your pc or Fing for your phone.
Try scanning the network, figure out which IP it has and try acessing it within your browser with the port 8123. Eg. 192.168.X.XXX:8123
If you don’t put any port after the IP, it means that you want port 80, which isn’t the right port.
Thanks a ton. I was entering the correct IP address, but didn’t add the :8123 at the end.
Problem solved. Thanks again.
Glad to help.
Mark your answer as answered clicking on that checkbox on the bottom right corner of my post that solved your problem.
So future readers can easily see it.
