I have a Telegram bot setup but cannot get any inline_keyboard commands to work. I have a test automation that turns off a light for “/command1.” If I manually type /command1 in Telegram, the light turns off. If I set up a notification with the keyboard parameter, the Command1 button turns off the light. But, if I use the inline_keyboard setup for my notification, clicking the Command1 button in Telegram just shows a spinning circle and nothing happens.
I have tried both polling and webhooks.
I have tried both parse_modes
Not sure where else to go.
inline_keyboard looks so much cleaner and professional to me so it would be nice to get it working. Here is my config:
CONFIG
telegram_bot:
- platform: polling
parse_mode: html
api_key: !secret telegram_bot
allowed_chat_ids:
- chat id
NOTIFY
- name: test_telegram
platform: telegram
chat_id: chat id
AUTOMATION 1
- alias: Telegram test2
- platform: event
event_type: telegram_command
event_data:
command: '/command1'
- service: light.turn_off
entity_id: light.upstairs
AUTOMATION 2
- alias: test telegram
- platform: state
to: 'on'
- service: notify.test_telegram
title: 'This is a test message'
message: 'Hello there this is a test'
inline_keyboard:
- "/command1"
Figured it out. I have to use the telegram_callback event type for inline_keyboards.
irqnet
(Christoph)
November 2, 2017, 2:02pm
3
Can you please share the working configuration? I’m facing the same problem right now. Tried it with the telegram_callback event allready, but it’s not working.
What I want to do is to send an message to the bot (like /ping ) and in return he sends me a reply with the inline keyboard where I can select a command that should be executed.
elRadix
(elRadix)
January 25, 2018, 9:49pm
4
anyone found the solution? is this a bug within home assistant?
vladosam
(Vladimir)
January 30, 2018, 5:56pm
5
This is part of my telegram configuration. I use it to control lights, creating hass backup and sending it with telegram etc.
# Telegram, Notify
- id: '4000'
alias: 'startup notification'
initial_state: true
hide_entity: true
- platform: homeassistant
event: start
- service: notify.telegram
message: 'Automata started'
keyboard:
- '/start'
message: 'Control panel'
inline_keyboard:
- 'Lights:/lights, Status:/status, Security:/security'
- 'System:/system, Help:/help'
- id: '4001'
alias: 'telegram alarm'
hide_entity: true
- platform: event
event_type: telegram_callback
event_data:
data: '/security'
- service: telegram_bot.answer_callback_query
data_template:
callback_query_id: '{{ trigger.event.data.id }}'
message: 'Alarm control'
- service: telegram_bot.edit_message
data_template:
message_id: 'last'
chat_id: '{{ trigger.event.data.user_id }}'
message: >
{% if is_state("input_boolean.burglar_alarm_door", "off") %}Alarm is OFF. {% else %}Alarm is ON. {% endif %}
{% if is_state("input_boolean.away_scene", "off") %}Presence simulation is OFF. {% else %}Presence simulation is ON. {% endif %}
inline_keyboard:
- 'Away ON:/away_on, Away OFF:/away_off'
- 'Alarm ON:/alarm_on, Alarm OFF:/alarm_off, Cancel:/cancel'
- id: '4002'
alias: 'telegram activate alarm'
hide_entity: true
- platform: event
event_data:
data: '/alarm_on'
- service: homeassistant.turn_on
entity_id: input_boolean.burglar_alarm_door
- delay: '00:00:01'
data_template:
data_template:
message_id: 'last'
message: >
inline_keyboard:
- id: '4003'
alias: 'telegram deactivate alarm'
hide_entity: true
- platform: event
event_data:
data: '/alarm_off'
- service: homeassistant.turn_off
- delay: '00:00:01'
data_template:
data_template:
message_id: 'last'
message: >
inline_keyboard:
- id: '4004'
alias: 'telegram ping pong'
hide_entity: true
- platform: event
event_data:
data: '/ping'
data_template:
message: >-
Callback received from {{ trigger.event.data.from_first }}.
Message id: {{ trigger.event.data.message.message_id }}.
Data: {{ trigger.event.data.data }}
{{now().strftime("%H:%M:%S %Y-%m-%d")}} Pong, Message from {{ trigger.event.data["user_id"] }}.
show_alert: true
- id: '4005'
alias: 'telegram control'
hide_entity: true
- platform: event
event_data:
command: '/start'
inline_keyboard:
