Can't get the DuckDns add-on to work
Fresh haos install on ProxMox.
I created a duckdns domain, and installed & configured the Duck DNS add-on; I’m getting the following errors in the add-on log:
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
INFO: Using main config file /data/workdir/config
  • Account already registered!
    [09:56:16] WARNING: KO
    [09:56:16] INFO: Renew certificate for domains: and aliases:
ERROR: domains.txt not found and --domain not given
[10:01:17] WARNING: KO
[10:06:18] WARNING: KO
Tried to google this error, and also looked around in this forum without any luck so far…
Thanks,
Denis.
Please share your configuration (via Edit in YAML).
Hi, your request put me on the solution path: there seems to be a bug in the UI for the Duck DNS add-on, with the domain name not being stored in the YAML file after ‘save’. I edited the YAML file manually, added the domain, and… everything worked!
Thanks!
