Can't get the snapshot image visible in a card (dashboard)
Can someone help with the following please. I’ve got a strange issue and can’t get the image into view.
With an automation I create a snapshot of my camera:
  - service: camera.snapshot
      filename: /media/snapshot.jpg
      entity_id: camera.camera1
This works because I see the image on that location:
But this code doesn’t seem to work:
type: picture
image: /media/snapshot.jpg
How my configuration looks like:
homeassistant:
  media_dirs:
    media: "/media"
  allowlist_external_dirs:
    - "/media"
Am I missing something?
Try this:
image: /local/media/snapshot.jpg
doesn’t work either. In the logs it says this:
looks like it’s related to onvif?
Logger: homeassistant.components.onvif
Source: components/onvif/camera.py:155
Integration: ONVIF ([documentation](https://www.home-assistant.io/integrations/onvif), [issues](https://github.com/home-assistant/core/issues?q=is%3Aissue+is%3Aopen+label%3A%22integration%3A+onvif%22))
First occurred: 20:30:33 (2 occurrences)
Last logged: 20:30:39
Fetch snapshot image failed from camera, falling back to FFmpeg; Unknown error: All connection attempts failed
First make sure the snapshot is being generated correctly, then only can you display it in a card. If it’s not, then the problem is with the entity that is supposed to generate the snapshot.
You can try to use the www folder for the snaphot.
/config/www/tmp/my_picture.jpg
My experience is that the media folder is not working for snapshots.
the strange thing is, I’ve tried your code and it saves the snapshot.jpg file there:
with this code:
      filename: /config/www/tmp/snapshot.jpg
But when I try to display the image, it breaks:
code:
type: picture
image: /config/www/tmp/snapshot.jpg
Ok try these:
type: picture
image: http://yourhassip:8123/local/tmp/auffahrt_snapshot.jpg
You have to add the ip / or webadress of your home assistent.
it becomes even more strange. I’ve tried these two, only the second one works (so an image is displayed):
  1. http://myip:8123/local/tmp/snapshot.jpg
  2. /local/tmp/snapshot.jpg
but it’s an older picture, not the most recent one. I guess it has something to do with caching?!
Hmm which photo is in the folder? The new one? Then clear the cache of the browser and you will see if this is the problem.
