Sorry I’m not a developer so probably something stupid, but can’t get this to work
If I create TTS requests with a service call node, (HA) then I get the value of the state with this option {{payload}}, so that works fine.
Now I want to use TTSUltimate with a function node, but what ever I try the, I always get the complete name of my sensor and not the value, what am I missing here?
Function node
msg.payload =
"The temperature is " +
"{{states.sensor.aqara_multi_sensor_buiten.state}}"
return msg
Flow
"id": "f474837fb704d0be",
"type": "tab",
"label": "DEV: Playing",
"disabled": false,
"info": "",
"env": []
"id": "cd3b3304bb50ce3c",
"type": "inject",
"z": "f474837fb704d0be",
"name": "",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "",
"payloadType": "date",
"x": 140,
"y": 180,
"wires": [
"2748f11d65adf119"
"id": "bca81ecd89833131",
"type": "debug",
"name": "",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "false",
"statusVal": "",
"statusType": "auto",
"x": 750,
"y": 200,
"wires": []
"id": "926fe72bf8f2f051",
"type": "ttsultimate",
"name": "",
"voice": "en-US-AnaNeural",
"ssml": false,
"sonosipaddress": "192.168.1.73",
"sonosvolume": "30",
"sonoshailing": "0",
"config": "dca49eeace6ac0f9",
"property": "payload",
"propertyType": {},
"rules": [],
"playertype": "sonos",
"speakingrate": "1",
"speakingpitch": "0",
"unmuteIfMuted": true,
"x": 750,
"y": 140,
"wires": [
"id": "2748f11d65adf119",
"type": "function",
"name": "",
"func": "\n\nmsg.payload =\n\n \"The temperature is \" +\n \"{{states.sensor.aqara_multi_sensor_buiten.state}}\"\n\nreturn msg",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 300,
"y": 180,
"wires": [
"eae80ae39106a182"
"id": "eae80ae39106a182",
"type": "link out",
"name": "",
"mode": "link",
"links": [
"07b8b0130836d144"
"x": 425,
"y": 180,
"wires": []
"id": "07b8b0130836d144",
"type": "link in",
"name": "",
"links": [
"eae80ae39106a182"
"x": 625,
"y": 180,
"wires": [
"926fe72bf8f2f051",
"bca81ecd89833131"
"id": "c0a34b3dc416a837",
"type": "inject",
"name": "",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "",
"x": 140,
"y": 280,
"wires": [
"af861d2f32b955ba"
"id": "fcc2e912e76771c1",
"type": "debug",
"name": "",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"targetType": "full",
"statusVal": "",
"x": 730,
"y": 280,
"wires": []
"id": "af861d2f32b955ba",
"type": "api-current-state",
"name": "",
"server": "36ba6f37c1b3f3c1",
"version": 2,
"outputs": 1,
"halt_if": "",
"halt_if_type": "str",
"halt_if_compare": "is",
"entity_id": "sensor.aqara_multi_sensor_buiten",
"state_type": "str",
"blockInputOverrides": false,
"outputProperties": [
"propertyType": "msg",
"value": "",
"valueType": "entityState"
"property": "data",
"value": "",
"valueType": "entity"
"override_topic": false,
"state_location": "payload",
"override_payload": "msg",
"entity_location": "data",
"override_data": "msg",
"x": 420,
"y": 280,
"wires": [
"fcc2e912e76771c1"
"id": "dca49eeace6ac0f9",
"type": "ttsultimate-config",
"name": "Azure TTS Service",
"noderedipaddress": "192.168.1.18",
"noderedport": "1980",
"purgediratrestart": "purge",
"ttsservice": "microsoftazuretts"
"id": "36ba6f37c1b3f3c1",
"type": "server",
"name": "Home Assistant Blue",
"version": 1,
"addon": false,
"rejectUnauthorizedCerts": true,
"ha_boolean": "y|yes|true|on|home|open",
"connectionDelay": true,
"cacheJson": true
Thanks in advance
