Hey guys,
I don’t know what I’m doing wrong, but I can’t get themes to work for the life of me.
I’m currently running 0.82.0
I’m trying to have:
- LoveLace as my default UI
- Themes selection under Configuration > General in the frontend UI
- themes.yaml to store my themes
For the life of me, I can’t get the themes to show in the configuration section of the frontend AND I can’t get any theme selection to actually effect anything except cards is lovelace.
Any help would be greatly appreciated.
Here’s configuration.yaml
homeassistant:
# Name of the location where Home Assistant is running
# Location required to calculate the time the sun rises and sets
latitude: !secret latitude_home
longitude: !secret longitude_home
# Impacts weather/sunrise data (altitude above sea level in meters)
elevation: !secret longitude_home
# metric for Metric, imperial for Imperial
unit_system: IMPERIAL
# Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: America/Los_Angeles
# Customization file
customize: !include customize.yaml
# Show links to resources in log and frontend
introduction:
# Enables the frontend
frontend: #!include frontend.yaml
javascript_version: latest
extra_html_url:
- /local/lovelace.html
- /local/custom_ui/state-card-mini-media-player.html
themes: !include themes.yaml
# Enables configuration UI
config:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
http:
# api_password: !secret api_password
# base_url: hassington.duckdns.org:8123
# ssl_certificate: /ssl/fullchain.pem
# ssl_key: /ssl/privkey.pem
# server_port: 8123
# Checks for available updates
# Note: This component will send some information about your system to
# the developers to assist with development of Home Assistant.
# For more information, please see:
# https://home-assistant.io/blog/2016/10/25/explaining-the-updater/
updater:
# Optional, allows Home Assistant developers to focus on popular components.
# include_used_components: true
# Discover some devices automatically
discovery:
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
# Enables support for tracking state changes over time
history:
# View all events in a logbook
logbook:
# Enables a map showing the location of tracked devices
map:
# Track the sun
sun:
# Weather prediction
- platform: yr
# Text to speech
tts:
- platform: google
cache: true
cache_dir: /tmp/tts
# Cloud
cloud:
group: !include groups.yaml
script: !include scripts.yaml
# Integrated Components
#iOS App
ios:
#Arlo
arlo:
username: !secret arlo_username
password: !secret arlo_password
#Camera
camera:
- platform: arlo
ffmpeg_arguments: '-pred 1 -q:v 2'
#MyQ
cover:
- platform: myq
username: !secret cover_username
password: !secret cover_password
type: chamberlain
#Nest
nest:
client_id: !secret nest_client_id
client_secret: !secret nest_client_secret
#Z-Wave
zwave:
usb_path: /dev/ttyACM0
device_config: !include zwave_device_config.yaml
