Can't get thi Scheduler to work
Ha
I’m trying tu get my working automation schedule to work with the adition of day of the week schedule.
My initial working code is this:
- id: Sprinkler_Schedule
  alias: Sprinkler Schedule
  - minutes: /1
    platform: time_pattern
    seconds: '0'
  condition:
  - condition: template
    value_template: '{{ states(''sensor.time'') ==  states(''sensor.sprinklertime'')}}'
  - data:
      entity_id: switch.sprinklerzone1
    service: homeassistant.turn_on
  - delay: 00:0{{ states.input_number.valve1.state | int }}:00
  - data:
      entity_id: switch.SprinklerZone1
    service: homeassistant.turn_off
  - data:
      entity_id: switch.SprinklerZone2
  - delay: 00:0{{ states.input_number.valve2.state | int }}:00
  - data:
  - data:
      entity_id: switch.SprinklerZone3
  - delay: 00:0{{ states.input_number.valve3.state | int }}:00
  - data:
  - data:
      entity_id: switch.SprinklerZone4
  - delay: 00:0{{ states.input_number.valve4.state | int }}:00
  - data:
  - data:
      message: Sprinkler done.
    service: persistent_notification.create
Now I added the needed input_boolean to define the days of operation, and added some condition and, or , With template, and using state function, niether are working … any clue to hel me ?
My automation using template:
  - minutes: /1
    seconds: '0'
  condition:
    condition: and
    conditions:
    - condition: or
      conditions:
        value_template: '{{ states(''input_boolean.monday'') == on }} and states(''sensor.dayoftheweek'') == Monday }}'
        value_template: '{{ states(''input_boolean.tuesday'') == on }} and states(''sensor.dayoftheweek'') == Tuesday }}'
        value_template: '{{ states(''input_boolean.wednesday'') == on }} and states(''sensor.dayoftheweek'') == Wednesday }}'
        value_template: '{{ states(''input_boolean.thursday'') == on }} and states(''sensor.dayoftheweek'') == Thursday }}'
        value_template: '{{ states(''input_boolean.friday'') == on }} and states(''sensor.dayoftheweek'') == Friday }}'
        value_template: '{{ states(''input_boolean.saturday'') == on }} and states(''sensor.dayoftheweek'') == Saturday }}'
        value_template: '{{ states(''input_boolean.sunday'') == on }} and states(''sensor.dayoftheweek'') == Sunday }}'
  - data:
  - data:
  - data:
  - data:
  - data:
  - data:
  - data:
  - data:
  - data:
My automation using States :
  - minutes: /1
    seconds: '0'
  condition:
    condition: and
    conditions:
   - condition: or
     conditions:
     - condition: state
       entity_id: input_boolean.monday
       state: 'on'
     - condition: and
       conditions:
       - condition: state
         entity_id: sensor.dayoftheweek
         state: Monday
    - condition: or
      conditions:
      - condition: state
        entity_id: input_boolean.tuesday
        state: 'on'
      - condition: and
        conditions:
        - condition: state
          state: Tuesday
    - condition: or
      conditions:
      - condition: state
        entity_id: input_boolean.wednesday
        state: 'on'
      - condition: and
        conditions:
        - condition: state
          state: Wednesday
     - condition: or
       conditions:
       - condition: state
         entity_id: input_boolean.thursday
         state: 'on'
       - condition: and
         conditions:
         - condition: state
           state: Thursday
     - condition: or
       conditions:
       - condition: state
         entity_id: input_boolean.friday
         state: 'on'
       - condition: and
         conditions:
         - condition: state
           state: Friday
     - condition: or
       conditions:
       - condition: state
         entity_id: input_boolean.saturday
         state: 'on'
       - condition: and
         conditions:
         - condition: state
           state: Saturday
     - condition: or
       conditions:
       - condition: state
         entity_id: input_boolean.sunday
         state: 'on'
       - condition: and
         conditions:
         - condition: state
           state: Sunday
  - data:
  - data:
  - data:
  - data:
  - data:
  - data:
  - data:
  - data:
  - data:
    platform: template
    value_template: >
      {% set today = 'input_boolean.' ~ (states('sensor.dayoftheweek') | lower) %}
      {{ states('sensor.time') == states('sensor.sprinklertime') and is_state(today, 'on') }}
  - data:
  - data:
  - data:
  - data:
  - data:
  - data:
  - data:
  - data:
  - data:
Explanation:
  • The first line of value_template creates a variable called today. This variable contains a string with the current day. Today is Sunday so it will look like this: input_boolean.sunday
  • The second line checks if the current time is equal to sprinklertime and if input_boolean.sunday is on.
  • If all tests are true then the automation proceeds to execute the action.
  • Because value_template contains the sensor.time entity, it will be evaluated every minute (because sensor.time changes state every minute).
Note:
I don’t believe the delay templates need an int filter (the result of a template is always a string). Nevertheless, I Ieft them as-is; you can remove them if you wish. They’re needed because the state value of an input_number is a string in the form of a float.
I’ve got a sensor template to format the output of my hour and minutes input_number slider to the 00:00:00 format of the time sensor, so it add a leading 0 in case the chosen value are one digit.
This part work allright, my problem is with the “and”-“or” conditions
  sensors:
    sprinklertime:
      friendly_name: 'Sprinkler Time'
      value_template: '{% if states.input_number.sprinklerhour.state|float < 10%}0{% endif %}{{ states.input_number.sprinklerhour.state | int }}:{% if states.input_number.sprinklerminutes.state|float < 10%}0{% endif %}{{ states.input_number.sprinklerminutes.state |int }}'
The conditions are not required if you use the Template Trigger I shared in my previous post.
The template of sensor.sprinklertime can be reduced to this:
  sensors:
    sprinklertime:
      value_template: >
        {{ '{:02d}:{:02d}'.format(states('input_number.sprinklerhour')|int, states('input_number.sprinklerminutes')|int) }}
Greate, it’s workin as intended :rofl: :grinning:
Thank you so much
