Disclaimer, I am new to playing with Home Assistant, about 2 weeks into it. I have been able to get various switches, dimmers and wall outlets up and running. That being said, I am having problems with the Honeywell ZW3107 Dimmer.
It is exhibiting the exact same behavior as described in this thread:
I cannot get it to turn fully off. It will turn off, but the light is left on with a very low modulation, so very dim.
This product is made by Jasco. Who also makes the GE Enbrighten product that is mentioned in the above thread.
Based on the manuals, the configuration parameters for the GE and Honeywell are identical:
GE: http://manual.zwave.eu/backend/make.php?lang=en&sku=28167%20(ZW3104)&cert=ZC10-15080013
Honeywell: {Sorry, being a new user I cannot add a third link to my post. }
But when I follow the directions in the thread, there are no “Node Config Options” available through the GUI to configure.
Here would be a list of questions:
How can I fix this problem?
When you add a node, where do the options and defaults for the product come from? I tried looking through the Home Assistant Repo, but didn’t have any luck.
Any help would be appreciated. Thanks
