I am brand new to HASS, so I hope I am posting this in the correct place.
Based on the following github post it appears that Venstar integration worked with the T5800 thermostat back in 2018: https://github.com/hpeyerl/venstar_colortouch/issues/4 (unless I’m mistaken, which could be the case…if so, please let me know).
I have tried to integrate my T5800 with Home Assistant, but with no success so far. I get the following error in my logfile:
2020-05-10 17:08:13 ERROR (SyncWorker_8) [venstarcolortouch.venstarcolortouch] Error requesting https://192.168.0.11/query/sensors from Venstar ColorTouch.
File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 160, in _new_conn
(self._dns_host, self.port), self.timeout, **extra_kw
File "/usr/local/lib/python3.7/site-packages/urllib3/util/connection.py", line 84, in create_connection
raise err
File "/usr/local/lib/python3.7/site-packages/urllib3/util/connection.py", line 74, in create_connection
sock.connect(sa)
ConnectionRefusedError: [Errno 111] Connection refused
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 677, in urlopen
chunked=chunked,
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 381, in _make_request
self._validate_conn(conn)
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 976, in _validate_conn
conn.connect()
File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 308, in connect
conn = self._new_conn()
File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 172, in _new_conn
self, "Failed to establish a new connection: %s" % e
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPSConnection object at 0x7f8c30dbdf10>: Failed to establish a new connection: [Errno 111] Connection refused
File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 449, in send
timeout=timeout
File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 725, in urlopen
method, url, error=e, _pool=self, _stacktrace=sys.exc_info()[2]
File "/usr/local/lib/python3.7/site-packages/urllib3/util/retry.py", line 439, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='192.168.0.11', port=443): Max retries exceeded with url: /query/sensors (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f8c30dbdf10>: Failed to establish a new connection: [Errno 111] Connection refused'))
File "/usr/local/lib/python3.7/site-packages/venstarcolortouch/venstarcolortouch.py", line 126, in _request
auth=self.auth)
File "/usr/local/lib/python3.7/site-packages/requests/api.py", line 76, in get
return request('get', url, params=params, **kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/api.py", line 61, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 530, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 643, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 516, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='192.168.0.11', port=443): Max retries exceeded with url: /query/sensors (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f8c30dbdf10>: Failed to establish a new connection: [Errno 111] Connection refused'))
2020-05-10 17:08:13 ERROR (SyncWorker_8) [homeassistant.components.venstar.climate] Failed to update data
2020-05-10 17:08:13 ERROR (MainThread) [homeassistant.setup] Error during setup of component zeroconf
File "/usr/src/homeassistant/homeassistant/setup.py", line 175, in _async_setup_component
component.setup, hass, processed_config # type: ignore
File "/usr/src/homeassistant/homeassistant/components/zeroconf/__init__.py", line 42, in setup
zeroconf = Zeroconf()
File "/usr/local/lib/python3.7/site-packages/zeroconf/__init__.py", line 2153, in __init__
interfaces, unicast, ip_version, apple_p2p=apple_p2p
File "/usr/local/lib/python3.7/site-packages/zeroconf/__init__.py", line 2073, in create_sockets
listen_socket = new_socket(ip_version=ip_version, apple_p2p=apple_p2p)
File "/usr/local/lib/python3.7/site-packages/zeroconf/__init__.py", line 2011, in new_socket
s.bind(('', port))
OSError: [Errno 98] Address in use
I also get the following associated error:
2020-05-10 17:18:23 ERROR (SyncWorker_0) [homeassistant.components.venstar.climate] Failed to update data
I have enabled the local API on my thermostat, and it appears to have one open port, specifically port 80. If I point my webbrowser there, I get the following text:
{“api_ver”:5,“type”:“residential”}
Any and all help would be greatly appreciated. The thermostate integrated easily with google home and alexa through “skyport”.
Thanks in advance!
