Greetings,
Decided to start using widgets with the Home Assistant app but it’s not working for me. I have a OnePlus 7 Pro running Android 10 (Oxygen),tried with 2 different launchers, I use Nova and also tried with the OnePlus one (default). I tried 2 simple widgets, one to disarm my house alarm and the other one to switch on my office light but when I click on the widgets I get an “unable to send service call” message. One thing I noticed and I am not sure if it has or not something with the problem is that when I edit the widgets, I can see the Service in one line (correct) and then the entity ID on the second line is blank, I get the right entity id on the third line but with a comma in the end (as if I chose 2 which I haven’t ), screenshot is attached.
The app is running fine, I am able to see my dashboards and change any configuration there, including the alarm and the office light but I am not sure what’s going on. Any ideas? Thank you!
Edit: Just deleted all the data, reconfigured it and it is now working as expected, no idea what happened there
